Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 108
    Aug 2017
    #41
    Magandang araw po sa lahat, hingi lang po ng payo kabibili ko lang ng 2012 suzuki celerio for city driving pero nagkaka problema po ako sa 1st gear acceleration ko umaabot ako ng 3500 to4500 rpm bago uusad ang celerio lalo na pag may paakyat kahit sa humps o kaya sa trafic light naiiwan ako ng 20 meters puro busina abot ko meron po ba akong aayosin ? Salamat po in advance sa makakatulong ng advise.
    #42
    Quote Originally Posted by Levi roferos View Post
    worn clutch lining?
    Aug 2017
    #43
    worn clutch lining?
    thanks pa check ko rin, may nag sabi palitan ko raw nang spark plug na NGK iridium.
    #44
    i read some time back, that there are two kinds of iridium plugs. one is just as long- (or short-) lived as the other non-iridium plugs, while the other is truly long-lived.
    i just forget... which one...
    Aug 2017
    #45
    6 days ago, our Celerio 2016 model's a/c broke down. The car is barely 2yrs old and ran 70k. We went to SOLID since it's not anymore under warranty. They found out that the evaporator is clean and clear, but it has a hole on the part where the foam is glued on. SOLID tried to weld the oart, but ut's so thin that it just melts away upon contact with heat. The problem now is that we can't find an evaporator for our car. Suzuki San Fdo doesn't have one either. PLEASE HELP!!!!
    Apr 2014
    #46
    Try asking for other suzuki casa. Per order basis ata yan.
    Also, why is it not under warranty?
    Jan 2009
    #47
    Quote Originally Posted by Joseph&Tess View Post
    Less than 2 years old and already out of warranty? How so?
    Aug 2017
    #48
    Dahil naka 70K na daw po. Is that valid?
    Aug 2017
    #49
    Quote Originally Posted by chronicle View Post
    Yup, we asked suzuki, by order daw nga po. And almost x3 ang price.
    Naka 70k na daw po kase kaya wala na warranty. Moving parts daw is up to 20k lang na tinakbo. 😑
    Jan 2009
    #50
    I don't know with Suzuki but it is commonly 3 years or 100,000 km, whichever is higher.
    Try to talk to a different dealer.
Suzuki CELERIO Problems
