Results 11 to 17 of 17
March 11th, 2011 09:29 AM #11
I assure you 100% not ECU related iyan. if ECU related, either hindi na gumana ang sasakyan mo from the start palang. kung sensors like mass airflow naman, either erratic idling and jerking laging aabutin mo which is not your case. and trust me, mabuti nang fuel filter lang ang iniisip niyo sir dahil mahal ang ECU. isa pa sir, ECU's are built to withstand the lifetime of the vehicle.
clogged fuel filter nga iyan.
March 11th, 2011 08:59 PM #12
- Mar 2011
- 7
- Mar 2011
- 7
March 12th, 2011 04:02 PM #14Been to Speedlab, and looks like na hi-tension wire at coil ang sira... order basis din sa Links ung parts so bka next week pa dumating ung parts. I'll keep you guys posted. Salamat sa mga nag bigay ng tips!
- Mar 2011
- 7
March 17th, 2011 06:03 PM #15Hi Guys,
Update lng sa APV problem ko. Dumating na un i-order kong ignition coil, d nako kumuha ng hi-tension wire kc mukha nman ok at walang crack at voltage arching ung wires. So I've managed to install the right ingnition coil and mukhang na solved na ung missed fire problem ng APV ko, bumalik na rin ung hatak nya sa 1st and 2nd gear at wala na ung parang kumakabayo na andar after ko syang e road test. So after all hindi pala fuel pump at line ang problema, bad coil pala which is mas mura at madaling palitan compared sa full assy ng fuel pump. Got the orginal Suzuki coil at WRJ Banawe at 5.5k. try ko gamitin mmya to work sana maging smooth na totally and takbo nya.
One more thing, anyone knows the valve clearance ng APV?
Thanks.
- Oct 2014
- 4
October 26th, 2014 01:17 AM #16
- Oct 2014
- 4
October 26th, 2014 11:59 PM #17How to solve fuel filter problem?is it different from ignition coil?super mahal kasi 18k.and i want to make sure yun nga ang sira bago ko palitan.Thanks
