Results 481 to 490 of 691
- Jul 2010
- 109
April 18th, 2011 03:54 PM #482
just change the brake proportioning valve in my vitara. hopefully this solves the brake fading when i make u-turns(weird cause it only happens on u turns) and it also caused my brake fluid to turn rust in color even for just 20 kms run, we found that the lip where the rubber boot sits is chipped by bout .5 inches, so maybe water sips in thru it. also change 1 front brake piston.
April 27th, 2011 11:21 PM #483
would it be possible to just do a simple body lift like say 3" instead of the usual suspension lift pa which is more expensive. Then after the lift maybe a 30" AT tires. I just want to give the vit a stance na mataas and wade through floods.
Maybe masters out there can tell the pros and cons of body and suspensions lift. thanks!
April 27th, 2011 11:26 PM #484
April 28th, 2011 06:00 PM #485
kung body lift the hoses and tubes of the aircon kelangan palitan kasi sakto lang sukat ng mga yun. alam ko yung brake line meron ilan papalitan din daw kasi maigsi din.
tapos yung kambyo lulubog kasi maiiwan yung tranny attached to the chassis.
your engine is still the same height since the chassis was left in it original height so going thru floods will still be the same.
cons... more body roll on turns.
ask the vitara guys in 4x4.ph
- Jul 2010
- 109
April 29th, 2011 01:43 AM #486sir impulzz around how much ba ang suspension lift? sa normal/usual na height increase?
April 29th, 2011 04:57 PM #487
my friend once mentioned about 30k at least. didn't ask for the brand though. mga 2" lift ata yun.
- Jun 2008
- 24
May 2nd, 2011 08:25 AM #488
Medyo marami pala cons pag body lift.. ito yata pinaka murang method pero dami dapat consider..
Question po sa gulong, may significant change ba sa gas consumption if mag change from 195 70 15 to 215 70 15 or 225 70 15. Currently am using 195 and I am getting 8 to 9km per lit on city with a very light foot on the pedal manual tranny po.
- Jul 2010
- 109
May 16th, 2011 05:52 PM #489Hi guys,
Has anyone of you had some body repair on your vit? Got hit by an LPG delivery truck last week. Would like to know what are the recommended body repair shops near Las Pinas or Makati area.
Thanks,
/Kenn
May 16th, 2011 10:25 PM #490
ouch, sorry to hear that.
i had my faded hood repainted at my friends paint shop here at araneta.
Konstruksyon ng Metro Manila Subway Project, ininspeksyon ni PBBM PTV Philippines
Metro Manila Subway 2022/2025
