Results 291 to 300 of 304
December 7th, 2019 11:28 PM #291
From what I've gathered, every 20K is best. Someone clocked more than 100K with no problem. NS3 is expensive though and the CVTF spout (or tube) is hard to reach. What happens is that the filter gets clogged with sediments and whatnot then it starves the transmission because the fluid can't pass through to lubricate and cool the components.
Also, you need to level the CVTF while it's in operating temp. So with the engine running, you need to lift the car and remove the plug bolt (or something like that) to make sure it's not overfilled or underfilled.
Complicated so I just got rid of it. The 1.8 would've been great in manual though.
December 7th, 2019 11:30 PM #292
December 7th, 2019 11:38 PM #293
December 7th, 2019 11:45 PM #294
December 7th, 2019 11:51 PM #295
December 7th, 2019 11:57 PM #296
December 8th, 2019 12:00 AM #297
December 8th, 2019 12:03 AM #298
December 8th, 2019 12:05 AM #299
December 8th, 2019 12:07 AM #300
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
