View Poll Results: What is your tire pressure? (front tires if front & rear tires aren't the same)
- Voters
- 288. You may not vote on this poll
24 & less psi
2 0.69% -
25-26 psi
3 1.04% -
27-28 psi
15 5.21% -
29-30 psi
110 38.19% -
31-32 psi
88 30.56% -
33-34 psi
24 8.33% -
35-36 psi
31 10.76% -
37-38 psi
6 2.08% -
39-40 psi
7 2.43% -
41 & up psi
2 0.69%
- Nov 2004
- 45
August 24th, 2010 10:01 AM #203Guys patanong naman
Ano advisable tire pressure for a sedan (altis). Daily I drive from SLEX Laguna Calamba to Manila.
Normal load is 1 to 2 persons. Driving speed is 100 to 130 kph at SLEX
When I leave home, I pass by a shell station and have them fill up the tires at 30 psi. At the following day I did the same routine with the pressure going down to 29 in one day Travel route is Manila to SLEX Calamba Laguna.
Is it just me or I feel that the tires is loosing air pressure in just one day. (1 - 2 psi) .
and
How often do you have your tires fill up ?
Thanks in advance !!Last edited by Icis; August 24th, 2010 at 10:03 AM. Reason: added information
August 24th, 2010 10:09 AM #204
August 24th, 2010 10:43 AM #205
I use 33psi on all fours on my zz. 195/60R15.
Always air up when your tires are cold. If you can't then air up a little more than usual, buy a good air gauge, then adjust the air at home after parking overnight.
August 24th, 2010 10:51 AM #206
kadalasan umaga kumakarga ng gas out side the subdivision. gas station ay mga 2 km+ from the house. so basically malamig pa ang mga tires.
every mid at end of the month, after kumarga ng gas, pa hangin. mid at end of the month para hindi makalimutan.
- Jun 2010
- 45
September 17th, 2010 05:39 PM #207civic vti 98
38 psi front - Goodyear Duraplus 185/65 R14
35 psi rear - Goodyear Ducaro 185/65 R14
is this fine mga sir? is nitro safe? balak ko kasi nitro ang ipahangin eh.
October 5th, 2010 02:38 PM #209
2024 Honda City V with Honda Sensing: 5 Things we like | Top Gear Philippines Top Gear Philippines
2020 Honda City
