Results 11 to 16 of 16
February 10th, 2010 04:33 PM #11
ano po ba ang tamang PSF sa isuzu gemini 98 model. naubusan po kc ang fluid yung kotse ko eh kabibili ko lang sya last january. Ang ATF po ba ay pwede na sa kotse ko?
many thanks,
voldor
- Oct 2009
- 72
February 14th, 2010 09:11 AM #12Power Steering System are less complicated systems compared to Automatic Transmission, in fact its only function is to lessen the driver's effort in steering the car, there are no special thing about them compared to automatic transmission fluid requirement. They are like most hydraulic systems, same as with your ordinary bottle jack, crocodile jack, car lifter, whereas automatic transmission operate more into extreme heat, more power transfer, longer working time. So I think ATF (automatic Transmission Fluid) are more than enough to pass the requirement of Power Steering FLuid, as with honda power steering system, they are the same in design with other power steering system.
February 14th, 2010 11:11 AM #13
- May 2006
- 32
September 22nd, 2013 02:12 PM #14Ang power steering fluid specs na nakalagay sa owner's manual ng VW Polo is: Audi/VW hydraulic oil G 002 000. Does anyone know kung anong locally available na psf ang compliant sa ganyang specs/grade? TIA
September 30th, 2013 02:37 PM #15
For my Corolla GLi, any Dexron type ATF, pwede na. Use ko sa automatic transmission ay Whiz DIII/Merc ATF kaya yun na din gamit sa PS.
September 30th, 2013 03:09 PM #16
Daming issue ng SU7:grin:
Xiaomi E-Car
