Results 1 to 5 of 5
June 20th, 2011 02:42 AM #1
sir ganitong ganito yun problem ko pag dahan dahan nag bbrake. what could it be?
YouTube - ‪Car noise while breaking lightly, but not when braking hard‬‏
June 20th, 2011 06:48 AM #2
make/model/year/mileage/last thing done with the brakesand mileage??? the noise demonstrates either warped rotors from overtightening the wheels or from being too thin below the minimum thickness. or, the car had been sitting in an area that gets the rotor wet and some spot got rusted thinner than the rest of the rotor braking surface
June 20th, 2011 11:41 AM #3
nissan sentra series III 1995 130km ...nagpalit na ko brakepads and rotors sa front. yun likod hindi pa. pero yun sound nanggagaling sa may driver side.
June 20th, 2011 02:31 PM #4
uneven mating of pad and rotor....
pwede ring wala sa align yung rotor, or yung wheel bearing
June 21st, 2011 06:43 AM #5
if the rotor had been replaced with a new part, there is still a chance that rotor is defective or the mating surface on the hub has foreign material preventing the rotor to sit true and perpendicular to the shaft axis causing a wobble. improper torquing sequence and torque amount causes warped rotors too. specially if the wheel was installed with an impact wrench without the "torq stik" torque limiter.
Daming issue ng SU7:grin:
Xiaomi E-Car
