Results 11 to 16 of 16
- Mar 2007
- 68
May 1st, 2007 02:37 PM #12hmm, marami causes yan. try wheel balancing and wheel/camber alignment first, pag hindi pa rin... well something deeper na yan. things like suspension failure: bushings or sa shocks, pede din busted bearings or worn cv joint (may alog na), check mo din ung stabilizers, tire rod ends and steering rack ends.. any one of those that fails, it can cause your front wheels to vibrate and wobble. goodluck!
May 2nd, 2007 04:21 AM #14
Also, check your lug nuts. Make sure they're re-tightened. I had 2 loose lugs on my front right tire, and I got wiggling.
- Apr 2007
- 1
May 2nd, 2007 12:57 PM #15Dude, I also have the same problem with my SL lancer boxtype. I tried replacing the tie rod kasi worn out na rin but the same problem exist. Nag pachamber na ako pero ganun parin yung problem at 70kph to much wiggle. Kahapon ko lang pina check sa mechanic dito sa QC and guess what, yung left ball joint ko palyado na. Pinapalitan ko na ng bago left and right. Tried cruising for 100kph last night and no wiggle and even a quick brake it doesnt wiggle. Check mo lang.
- Nov 2006
- 132
May 14th, 2007 09:21 PM #16Exacto! nangyari na sa akin ito with my VTI.
Nanginginig ang buong car after 70kph. Akala ko ng engine support ang problem.
Hindi pala balanse ang rear tires ko. Pinapalitan ko lang ng magkapareho ang tire wear. Okey na! Parang bagong-bago tumakbo walang vibrations kahit na nag 140kph pa!
Daming issue ng SU7:grin:
Xiaomi E-Car
