Results 21 to 28 of 28
- Apr 2009
- 1,902
December 21st, 2010 03:26 PM #21
- 154
December 21st, 2010 03:44 PM #22
- 154
December 21st, 2010 05:58 PM #23mga bro anong magandang brand ng rotor disc for civic lxi?
nagtanong kasi ako sa servitek kung magkano pa reface bale 1250 per wheel.. halos kapresyo na ng replacement rotor disc..
ok ba yung replacement lang? or pareface ko na lang?
tsaka ilang disc po ba meron per wheel?
December 21st, 2010 06:20 PM #24
Well you know, all rotating parts in a car are subject to vibrations. Brake drums, propeller shafts, flywheels and engine crankshafts are all balanced to counter the vibrations.
Old, worn-out tires may have uneven patches and bulges enough to vibrate even at moderate speeds, and if the belts are separated already. Or still possible, the old tires on their rims were just out of balance and when you replace it with new ones, the tech balanced the wheel and eliminated the wiggle. Remember that as the tires wear out say in a few months, the state of balance changes so you have to do it again.
To use an analogy, an old electric fan with bad rotors will shake slowly in the first setting, then vibrate wildly in 2nd, and will be steady at 3rd or maximum setting because the speed compensated for the imbalance.
- 154
December 21st, 2010 06:47 PM #25
December 22nd, 2010 11:24 AM #26
As i've said, the culprit could be the rotor disc. Honda Lxi has 2 front wheel disc brakes, 2 wheel rear drum brakes. If i remember it right, meron sa mga servitek nag rereface ng rotors, around 750 per disc yata.
- 154
December 22nd, 2010 03:00 PM #27
- Jul 2009
- 31
December 23rd, 2010 08:45 AM #28most likely tama si howard kasi ganyan na ganyan ang nangyari sa crv ng friend ko basta pag nagbrake ka lang nagbavibrate warped rotor yan, kasi kung yung mga parts ng suspension ang sira minsan di ka pa nagbrake ramdam mo na saka di specifically vibration ang symptoms.
