Results 1 to 9 of 9
- Feb 2008
- 73
October 24th, 2009 02:20 PM #1almost 70% thread pa tires ko sa front pero sa inside ay pudpod na. parang 45 degree angle itsura ng 1st thread from the inside. tama naman sa hangin timbang naman ang gulong bakit ganun. doubt ko ay pag lumiliko kaya nagkakaganun. plan ko ay ilipat gulong sa likod sa harap pero naiisip ganun din siguro mangyayari. sayang naman.ano po ba cause nun at ano dapat pagawa? balancing ba tawag dun?
October 24th, 2009 02:46 PM #2
sir kailangan nyo po ng wheel alignment(camber/caster ba tawag dun) pag ganun na hindi pantay yung kain ng gulong...most servitek branch can do that kind of job..
- Feb 2008
- 73
October 24th, 2009 03:53 PM #4
sir depende sa shop at sa mga kailangan parts na papalitan...
budget ranges from 1k-3k siguro...
Tsikot Member Rank 4
- 1,842
October 24th, 2009 04:20 PM #5try mo ito
http://books.google.com.ph/books?id=...gnment&f=false
so far gumana sa akin ang technic na ito, APV kasi is known for having disaligned camber (Factory defect)
The thing is, wala sa align ang steering, pero ni rotate ko muna tires (front back) naalign ulit steering, so the real problem is camber lang.
Hindi naman ako bilib duon sa technic na kinikikil yung shocks to Camber align the tires so i tried the link above so far mukhang ok naman
According din kasi sa mga site Mga Mcpherson shocks motsly doesnt required camber
- Feb 2008
- 73
October 24th, 2009 09:20 PM #6ah may parts palang papalitan?
*max sige i'll try the link, tagal mag-open eh hehe. bagal dsl.
October 24th, 2009 10:05 PM #7
The best siguro pa check mo muna sa gumagawa ng wheel alignment para makita nila parts ng suspension na papalitan at pag naayos na lahat at saka nila i wheel aligment para magpantay upod ng gulong.
- Apr 2009
- 536
October 26th, 2009 12:06 PM #8sa tingin ko rotate mo muna, i mean yung inner mo na pudpod gawin mong outer.
i think if pina camber or allignment mo yan its too late, you have to buy
new set of tires para mas accurate ang pag camber. d rin ako masyado naniniwla sa allignment. minsan malubak lang bumabalik sa dati, puede siguro if new set of tires pag luma na hayaan mo na.
THE AUTO SPECIALIST
- Mar 2006
- 607
