Results 21 to 24 of 24
June 28th, 2005 10:59 AM #21Originally Posted by Ungas
kung maayos ba ang alignment tas ng pa suspension lift kit ganun parin ang tread wear?
Originally Posted by Shadetree MKNX
- Jun 2005
- 113
June 28th, 2005 01:55 PM #22Originally Posted by notEworthy27
If the t-bar springs were repositioned to add more ride height, then yes, that would affect the amount of flex on the control arms, indirectly adding more positive camber. That is definitely the WRONG way to do a lift on an independent suspension system.
July 11th, 2005 11:15 PM #23
yung kotse ko naman po inner portion ang mabilis mapudpod... lalo napo sa rear... ganun ba tlaga pag lowered ang kotse? mabilis mapupod ung sa inner part? so camber alignment padn ang solution tama po b?
December 19th, 2005 06:39 PM #24
mga sir, bago driver po ako and nakabili me ng honda civic 95. kaso, medyo upod na po yung inner-tires sa harap. may nagsabi sakin camber adjustment daw ito or di na aligned yung front tires kaya di balance yung kain ng mga gulong. please give me any service center para dito sa problem ko together with the contact and complete address. pakisamahan narin po ng directions kung paano pumunta doon. balak ko pong pumunta sa wednesday para di matao if ever. pandacan-manila area po ako. thanks in advance.
