Results 11 to 18 of 18
- Feb 2006
- 771
September 25th, 2007 02:03 PM #11mga sir
any idea how much yung repair pag axle bearing yung sira?pwede b one side lng palit nito?
September 25th, 2007 08:49 PM #12
di kaya madumi lang brake pads mo? ganun din car ko, pag slowing down. Then i had the brake pads cleaned, okay na. P100 pesos lang bayad ko, actually tip na lang yun.
- Feb 2006
- 771
September 26th, 2007 10:55 PM #13one side lang nman po nag iingay sir e,
pero try ko na rin po tsek kung madumi nga salamat din s input sir,
tsaka dun po sa Q ko na kung sakaling axle bearing nga po sira bale ano po usually pinapalitan d2?yung CV po b tska boot nun sinasabay n rin?pwede po b isang side lan palitannun?
ano po b recommended nyo n mag ayos nun ?ZAFRA?Servitek kya?o yung friendly neighborhood mekaniko natin?any idea kung gaano katagal ayusin to mga sir?
HElp naman po sir nkakaktakot bka bigla n lng humiwalay gulong ko pag tumatakbo e!or bka me madamay pa n mga sira pag d naayos kaagad huhuhuhu
salmt po uli sa mga inputs sir
September 27th, 2007 12:30 PM #14
normally, palit na rin ng boot kasi yun din isang cause, baka punit na, and dun pumapasok tubig and alikabok.Yun din ang usual cause kaya natuyo ang axle grease. Kung ano lang yung sira, yun lang din palitan. Bettrer check din tyhe other side baka maagapan mo pa, palitan mo na rin boot pag may punit.Kung kakilala mo mechanic, better, or recommended by friends.
September 29th, 2007 04:58 AM #15
try mo pa-check ang wheel bearings. nagkaganyan din yung pick-up ko nun. kala ko gulong, yun pala bearings.
- Sep 2007
- 215
September 29th, 2007 06:11 PM #16simple lang yan ...
kung straight road and maingay ... like shreeking with a little krug krug ... wheel bearing yan pakiramdaman mo nalang kung which side
kung turning and may krug krug krug while turning ... velocity joint na ang problem mo ...
pag humps and may krug ... shocks or suspension na problem mo
i think your problem is wheel brg ... either replace it or grease it ...
BANAWE AUTO SUPPLY
regy
09178999989
nurse on wheels
- Dec 2006
- 392
September 29th, 2007 09:51 PM #17bring it to a trusted mechanic if you want your questions to be answered. have it diagnosed, if you don't agree with the diagnosis get a second or third or fourth opinion. a waste of time, but that;s how it is if you have a car.
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 30th, 2007 02:06 PM #18for problems that have to do with sounds it is best to have a mechanic listen and diagnose. it's very hard to do online.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
