Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Feb 2006
    mga Sir,
    Good day po,tanong ko lng po sana kung ano b yun pwede dahilan pag tumutunog yung front wheel ko if i am slowing down?parang sumasabay sa gulong e , parang "krug , krug krug " kaso di ko malaman kc intermittent e minsan meron minsan wala e!
    tska pag kinakabig ko steering to the max me tumutunog n me sinsayaran yta!
    ano po kaya problem nito?
    help nmn po mga sir
    me isa p kc k problem mga sir,,
    yun po twing pagstart maingay yung elt yta , as in parang screeching sound pero after na mkatakbo sya ng mga 5 mins e nawawal nmn!sbi po minsan belt daw !
    pwede po b i DIY n lng yung belt change?any procedures to do?maselan po b pagppalit nito ?
    Aug 2003
    ano sasakyan mo pre?
    Quote Originally Posted by threx666 View Post
    mga Sir,
    help nmn po mga sir
    the sound could be due to lots of factors, bearing, bushings, joints, the brakes itself, etc. i would just suggest that you take it to a mechanic so it can be checked thoroughly.
    on the belt, baka tuyo na yung mismong belt so hindi na sya nakaka grip sa mga pulleys. you can have it DIY'ed pero medyo madugo ng onti, for one, you have to loosen the tension first so you can have it removed, put it back and put back the tension of the pulleys JUST right... pag mali ang pagbabalik mo ng tension, mapuputol ang belt, mas malaking problema.
    Aug 2005
    screeching - have belts checked.
    krug, krug, krug - have cv joints checked. pwede mo ding check yung boot kung sira.
    Sep 2004
    Re: belt, you can have a mechanic adjust it. Since you're a relative newbie pagdating sa maintenance, better to let a pro handle it. Mura lang naman, baka pa-meryendahin mo lang yung mekaniko sa suking gas station, ok na.
    Yung "krug krug", hula ko suspension part ang salarin. I doubt kung CV joint yun. Kasi ang tunog nun, tok tok tok tuwing lumiliko. Pero since sabi mo may tunog kung kinakabig mo manibela, baka eto (CV joint) na nga sira.
    Feb 2007
    this is similar with my car. pag nagmenor na ako, umaalog alog ang sasakyan. pag mabilis ang takbo, wala akong maramdaman. mine is xto crosswind 2001. what do you think is the problem? wheel alignment lang kaya ito?
    Aug 2005
    analize it first if u press the brake pedal ska mytunog brake pads un.
    kung freewling k nman pwdeng axle bearing or oblong or bukol tires mo. may ganyan problema ung ibang 96-98 honda pgbtaw m ng gas pdal prominent ung ingay, ung factory tire mingay prang axle bearing n mccra na ( gdyear or frestone ata)
    Feb 2006
    actually mga sir,
    yung krug krug krug pla more on left side lng nmn side sya at during free wheeling n slowing down e!
    tpos pag kabig ko sya ng paliko n maximum e yun me tunog din n sumsayad sya!
    medyo idea ko nga sir me kinalaman sa CV yun tsaka boot nga ,pwede po b n one sidee lng yun nasira?
    ride po pala is 7G galant
    sa belt nmn po dapat b palitan ko yung mga belts ng sabay ?PS belt , belt ng Alternator b yun?tska me isa p yta dk napansin kung saan nkkabit e!(sori po medyo bago bago lng ngigicing s makina e!)
    salamat po ng marami sa mga input mga sirs
    ganyan din prob ko nuon, uhm sa belt ung screeching pag sagad yung kabig mo, may pinipihit lang ung mechanic na kakilala ko tapos aus na, wala pang 5 mins un, tapos ung krug krug, din sa axle bearing, pinachek ko un and pagtingin is durog durog na ung bearing! waah, aun replacement ng bearing kinailangan
    Feb 2006
    ah ganun po ba?
    malamang nga axle bearing cguro to
    mag sir any idea kung magkano palit nito?yung spare?gaano kya katagal palitan to?
    salamat po s reply at tips mga bossing
Tumutunog yung front wheel during slowing
