Results 11 to 20 of 43
- May 2011
- 3
May 26th, 2011 04:27 PM #11you can call or visit Tropical Motor Supply ay 1234 C. M. Recto Ave. Binondo Manila. Tel No. 244-8222, 244-8230. We carry the Orange Retrofit TPMS. Instructions are included to answer all your questions
June 3rd, 2011 08:52 PM #12
On the good side of the TPMS, it helps me monitor the tire pressure. For those with TPMS, change you air tires with nitrogen. It is about accurate possible....
June 9th, 2011 06:35 PM #13
TPMS can be bought at Winterpine
or
check this link
www.ultraracing.com.ph
June 9th, 2011 06:41 PM #14
i did not realize the usefulness of the TPMS until i had it
when i filled up with nitrogen, i put the ignition key to "ON", switch the MIS display to the TPMS and use this to monitor the nitro being filled. i rely more on this than the manual gauge to determine my tire pressure
it has become my habit to check the TPMS prior to driving and during the drive when i am at the stop light. it gives the PSI and tire temperature reading
June 9th, 2011 07:54 PM #15
^ by using nitrogen, it would definitely be as accurate as possible.
June 9th, 2011 08:09 PM #16
June 10th, 2011 04:37 PM #17
- Feb 2010
- 336
June 12th, 2011 10:42 PM #19
November 30th, 2012 08:58 PM #20
For those who had this installed (meaning, it did not come pre-installed when you purchased car), from whom did you source?
