Results 1 to 8 of 8
January 23rd, 2010 09:54 AM #1
mga sirs need advice
ano ba dapat i check pag me "tok tok tok" sound paglumiliko un oto ko sa kanan at kaliwa (mas malakas pag sa kaliwa ang liko),
pag deretso ok nmn sya wala tunog
thanks in advance
oto ko is corolla 97 gli (big body).
- Jul 2008
- 35
January 23rd, 2010 01:24 PM #4I think CV lang yun, hindi CVT. CV = Control Velocity. Not sure ako
mga 2k yata ang isa nun. dalawa bibilhin mo, kasi left and right.
January 23rd, 2010 03:05 PM #6
Oops... my headache is causing me some problems.
It's supposed to be CV joint.
Make sure to also to check if the CV boot (the rubber thingie covering it) is not torn. This helps keep the grease in and the water/dirt out of the CV. IF the rubber CV boot is torn, have it replaced as well.
- Oct 2009
- 72
January 31st, 2010 09:17 AM #7All of the above are right, it is the outer CV Joint, that are making to tok-tok sound, regreasing it will not remove the sound, it must be replaced. I will cost you less than 1K for each in banawe.
February 8th, 2010 12:25 PM #8
tnx mga sir, CV joint nga, had it replace at banawe, cost me 650 for each CV joint kasama na un grease and new rubber boot and 500 for the labor (for both wheels)
ok na sya ngayon.
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
