Results 11 to 16 of 16
Tsikot Member Rank 3
- Dec 2002
- 636
November 25th, 2004 09:54 PM #11benchph1
The RR of a 195/60R14 is 294.8mm so a bit smaller than orig but acceptable.
Can also use 205/60R14 with RR of 300.8mm which is larger by only 2.8mm.
- Nov 2004
- 68
November 25th, 2004 10:42 PM #12jackaroo, salamat bro. still have question f u dont mind, any negative effects if have this bigger tire?
- Dec 2002
- 636
November 26th, 2004 08:35 AM #13jaycv,
A bigger tire will make your gearing taller so less torque for acceleration but better fuel mileage on long trips. Will also affect the accuracy of your speedometer/ odometer.
If the car is used for daily driving, i would not go above a 1 inch increase over stock tires.
- Oct 2004
- 103
November 27th, 2004 04:30 PM #15guys what about 185/55/15. Im upgrading to 16" rims and prbably 45's or 50's depending on stance and look. What do u think should be the correct tire size? Thanks hope u guys can help
- Dec 2002
- 636
November 29th, 2004 10:04 PM #16alanranch
RR for 185/55R15 is 292.25
RR of a 205/45R16 is 295.45
A 50 series tire will be too tall vs orig spec.
Monk-owned R53
