Results 1 to 10 of 28
September 25th, 2003 09:42 PM #1
Napanood ko sa America Plus Channel (Good morning america). Na napag-aralan sa US na dapat may Expiry na rin daw ang gulong dahil delikado rin daw ito kung matagal na kahit di masyadong gamitin.
Anong sa tingin nyo?
September 25th, 2003 10:13 PM #2
ang pagkakaalam ko meron talagang expiry date ang mga tires. meron kasi itong nakatatak na manufacturing date sa tire wall, di ko lang alam kung ilan years ang expiry. tumitigas kasi ang goma kapag matagal hindi nagagamit.
Signature
September 25th, 2003 10:57 PM #4
when the tire is in regular use, its said to "expire" in two to three years depending on how severe the heat cycle the tire goes thru.
September 25th, 2003 11:29 PM #5
dito sa oil rig we have a special room for rubber spare parts. controlled ang temperature (cool around 25 degrees) and humidity must not be less than 50% but no more than 80%. pag mainit kasi lumulutong ang rubber, ganun din pag low humidity. pag sobra naman init saka high humidity lumalambot. pag masyado naman malamig kumukunat. and lahat may expiry date based on date of manufacture. most of the rubber parts we have here are marked by manufacturers with expiry dates but those expiry dates are dependent on proper storage conditions. kaya nga controlled namin ang temperature saka humidity ng "rubber room".
ganyan din ang tyres, lalo na exposed sa environment yan. kaya lang siguro wala pang expiry dates ang tyres kasi nga fast moving eh, pun intended hehehehe!
September 26th, 2003 01:35 AM #6
performance tires with softer rubber tends to wear out in under two years so thats no problem. But the long lasting tires like GoodYear Eagle NCT3 might still be rolling on the same car after 4 to 5 years.
Tsikot Member Rank 3
- Dec 2002
- 636
September 26th, 2003 05:45 AM #7Read an article before that mentioned tires on a vehicle that is seldom used should be changed after 6 years since they become brittle and tend to crack on the sidewall.
- Jul 2003
- 58
September 26th, 2003 10:06 AM #96 years after manufacture so company usually gives 5 years after sales ang expiry ng tires.
September 26th, 2003 04:50 PM #10
Yup, this is true. Even if brand new ang goma, basta old stock medyo hindi na up to standard yung rubber. 4 to 5 years ang alam ko.
Monk-owned R53
