Page 25 of 30 FirstFirst ... 15212223242526272829 ... LastLast
Results 241 to 250 of 299
    #241
    Quote Originally Posted by 170kphlang View Post
    sir redorange tnx sa reply, di po nka drop ang car ko stock tlaga lahat, ung pagrub po sa harap may magagawa po ba para di mangyari un or ano po suggest nyo na pang 17 mags tire size pero ndi 205 ung lapad ng gulong kasi 20mm din increase yun from stock na 185mm, i can see what you are trying to say
    If your front wheelwell is plastic you can use a heat gun or blow dryer to try and soften the plastic so you can mold so it won't touch. I myself just cut the plastic wheelwell so it doesn't touch when I turn. I kind of had to do that since my tires already rubbed on it and melted and ripped some of the plastic. I tried searching for 195 tire but I don't think they make it for 17's, maybe they have it in the Philippines.
    Mar 2007
    #242
    helo po...i would 2 ask 4 some suggestions. sa sis ko kc un honda crv nya na 98 model ngaun nsa abroad sya & pinapabili nya ako ng tires san po ba at anung brand ang mgandang bilhin????tga mandaluyong me.dko alam kc un mga tungkol sa mga dimension nya eh or any other details.may nkapag sbi sakin na un geolandar ng yokohama mganda daw.ok po b un???tsaka how much kaya ang cost ng bawat tires...tns much...ope mkapag suggest po kyo...
    #243
    Quote Originally Posted by maxymaxy View Post
    Unless your sister does any sort of off roading a highway biased tire may be better for her CR-V.
    May 2005
    #244
    mataas pa ang thread ng tires ko but it's been there for 2 years + a couple of months. Mataas din ang utilization ng car (60k km in 2 years).
    Is it really time to change? i was told na although from the outside the tires seem ok, compromised na raw ang loob.
    Mar 2007
    #245
    binabyahe po ng laguna un crv ng sis ko tpos kung gs2 ko po taasan un tires anung size po ba?eto po un size & brand of tires ko ngaun. bridgstone dueler h/t 215/70/r15....anu po b massugest nyo???? san dn nkkabili???sa west ave po b ok dun???tnx!!!
    #246
    Your current tire has a diameter of 26.85". If you want to go bigger keep in mind that it will affect your speedometer and your FC because of the added weight.
    #247
    Quote Originally Posted by resmile View Post
    Unless you drove the tire with a flat for an extended period of time the inside should not be compromised.
    Sep 2004
    #248
    205/40/17 fit my esi and lowered pa sya...but i suggest you get 45 instead of 40..with the road conditions here...40 is just too risky
    Mar 2007
    #249
    cge po kung mag stick na ang ako sa size na 215/70/r15 anu po ba mgandang brand na hndi masyado mahal???san po mkakabili nun???salamat po...
    Mar 2007
    #250
    panu ko po ba ma ddetermine kung surplus/2nd hand or brand new ang isang tire kung sakali bbili me sa place tulad ng blumentrit, evangelista or west ave???many tnx!!!
The Tire / Gulong Thread [Merged]
