Results 151 to 160 of 299
December 28th, 2004 10:13 AM #151
if i increase my tire size lets say from 185/65/14 to 195/55/15
do i also have to increase my tire pressure? dati 30 psi ang nilalagay ko sa mga gulong ko
December 28th, 2004 10:22 AM #152
Originally Posted by benchph1
yung fronts alam ko steady 30 yata. then yung likod lang nag vavary. pero 30 is the best guestimate for any vehicle's tire pressure.
January 19th, 2005 08:19 PM #154
hello mga sirs...and mams!
i just wonder..
kasi im planning na to change my Kelly multitrack 30x9.5 R15 tires i have now...im considering
1.dunlop grandtrek a/t2
2.bridgestone dueler a/t
3.yokohama geolandar a/t + II
of them i ruled out the dunlop...because of the feedbacks i've heard..(kasama ung mga dealer na di nagrecomend nun)kaya im left with the two...
im confused what to get..they're good tires..which do you all recomend?
and ask ko lang din...im considering this also...im planning to have
235/75R15LT size on the front and 30x9.5R15LT size on the rear..
is this set-up wise..considering my rear tires is 1.12204 inches higher and 0.24803 inches wider than my front tires?(planning not to rotate the front to rear tires,vice versa)or it is best to keep the sizes same for all tires..
thanx in advance!
January 20th, 2005 02:26 PM #155
teka... para sa anong kotse yan?
bridgestone duelers a/t are kinda ok naman... oem tires yan ng mga mini-SUVs (CR-V, Rav4). kaso nakakasawa na tingnan kasi pare-pareho kayo.
pero based sa specs mukhang mas ok yung geolander. ako na dismaya sa specs ng dueler nung nakita ko sa bridgestone website na sobrang dami pa palang variants ng dueler (low-end yung binebenta dito).
January 20th, 2005 02:42 PM #156
for my 4wd van(delica)...gusto ko nga sana dueler a/t revo..but cant find one and not available here,e..just got a pair of 235/75r15LT geolandars for my front tires for P10,120(tires,2 pito,16pcs lead,mags repair-->nasa other thread po ung breakdown,e.."which a/t tire" thread)mura kaya ito?
pinamount ko na ung while letters ay sa loob at ung black ay ung nakikita..
ask ko lang kung sa rear tires naman same size din or 30x9.5r15LT...will the 1 in height and .25 inch wide difference matter?
thanx po..
January 20th, 2005 02:50 PM #157
yun nga ang nakakainis dito sa pinas... yung mga mid to high variants ng mga tires eh hindi available... (tulad nung revo)...
kung kasama mags repair, baka pwede na yan... P4,500 ang kuha ko sa 235/60/r16 duelers
January 20th, 2005 03:03 PM #158
nga,e...kaya resorted to geolandars..1 variant lang,e...thanx din po sir mazda2
January 20th, 2005 04:21 PM #159
So halos pareho lang price ng geolandar sa Dueler? Hindi ba maingay? Due na rin ako for a tire change (for a delica 4WD also) naka bridgestone duelers me ngayon (235X75XR15). Kailangan na palit sa unahan. San mo nakuha yan? Also am considering 2nd hand tires tipong mga 90% pa (magkano kaya diff nito sa brand new?). Tnx
January 20th, 2005 06:40 PM #160
at 25 psi(un ang pinalagay ko...)ok naman...masmalabot kaysa sa dati ko...4050-4200 pesos ang geolandar 235/75r15LT..duelers 694 na sa ako..pero,di maganda reviews ng dueler 694...walang dueler revo dito sa pinas..havent heard yet..i'll know this sat,paguwi ko sa palayan...projector lights delica mo?mine kasi can fit a maximum size of 30x9.5r15LT(eto kasi size ko) kasi +2 inches up..sa rear tires ko, im fitting 30x9.5..
hard to find a used na di ganu gamit..
pic and post ko delica ko pag maganda na tayo muli...
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
