Results 1 to 10 of 14
November 14th, 2005 07:11 PM #1
The Ford Ranger steering wheel vibrates at around 80kph. I suspect a tire balancing job is needed, what is now the usual asking rate by reputable shops for tire balancing?
November 14th, 2005 07:32 PM #3
On second thought, could there be other causes for steering wheel vibrations at speed other than unbalanced tires?
- Jun 2005
- 3,770
November 14th, 2005 10:07 PM #4worn out suspension parts. balljoints/rackend/etc. better have it diagnosed at reputable shops or casa in your case if it is fairly new.
November 14th, 2005 10:18 PM #5
check the weights first. kung napansin mo kulang this could be the cause. however, there is more to it. baka may maluwag sa mga tie-rod ends mo or baka bumigay yung mga belts ng gulong mo. happened to me one time. yung contact patch animo may malignant tumor.
- Sep 2005
- 40
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 07:46 AM #7Originally Posted by ian_rex
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 04:09 PM #10may kabig parin sakin nka gastos na ako ng 2.5k para all wheel balance.. pa tulong nman.. nagpakabit kasi ako bagong tire-rod ins kaya pag align na sa mga front at back nagkaloko na.. hindi parin makuha ang alignment nila.. 1(caltex) 2(shell) 3(shop)..
3 times na may kabig parin sa left... elp mo mga tsikoters..
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
