Results 1 to 8 of 8
September 15th, 2008 01:03 PM #1
bakit po may steering sound kung nagsteteer po ako. may sira po ba?
September 15th, 2008 01:16 PM #2
can you describe the sound? san sya lumalabas? pag steering at the right? or at the left?
September 15th, 2008 01:24 PM #3
September 15th, 2008 06:28 PM #5
have the constant velocity joints checked. they might need to be replaced.
September 16th, 2008 02:29 AM #7
If you will look at your front axles, they have rubber boots on them. Two for each side, and inner & outter. These boots are full of grease for the CV joints they house. When a boot goes bad, they will sling all the grease out of them, and make a noise just like what you are describing. This doesn't mean your CV joints are bad (they could be) but it does mean they need looked at right away, and a new boot & grease installed before they do go bad. You can buy new boots for them that comes with a pack of grease and instructions on replacing them. These joints are very durable, and most of the time a new boot will fix the problem. I would have them looked at right away, and if they are worn out, you can trade them in for rebuilt shafts, and get them pretty cheap.
- Oct 2003
- 18
October 6th, 2008 12:20 PM #8mga sir ganito rin ung sa galant namen, pag nag u turn ka taposbabalik na ung steering wheel a gitna, maytuk tuk tuk na tunog hanggang makabalik ung steering wheel.. sabi nung mga nakausap ko na mekaniko baka daw stabilizer.. tama po ba un? and un ba ung napuputol?kasi may mga nakita na ko na kotse, mga bumagsak ung harap kasi ung gulong biglang umiba ng direksyon..salamt po
Just ordered backup charger. Will keep you updated...
