Results 11 to 20 of 26
October 30th, 2009 04:48 PM #11
By the mention of "Rapide", parang alam ko na kung bakit maingay. :D
Anyway, figure out which wheel is making the noise and inspect the brake pads. Don't base conclusions as to the condition of your brakes by just looking at the outer brake pad. Remove a couple of screws and slide out the brake caliper so you can get a good look at the inner brake pad.
You may also want to put copper grease on the BACK SIDE of the brake pads so it will dampen any noise caused by vibration (oscillations) when the brakes are applied.
- Oct 2009
- 14
October 30th, 2009 05:08 PM #12
October 30th, 2009 05:39 PM #13
Dami horror stories sa Rapide. http://tsikot.yehey.com/forums/showthread.php?t=26622
October 30th, 2009 05:46 PM #14
- Oct 2009
- 14
October 30th, 2009 06:11 PM #15uh oh. if i'm coming from the south alabang-las pinas-parañaque area, where is it advisable to have my car checked? ano ba shop ang maganda sa amin.
October 31st, 2009 02:54 AM #16
MAraming matinong shop diyan sa Las Pinas... look for a shop thats near to a Machine Shop. Madali lang naman magpalit ng Pads eh.
The first thing you need to do is - buy the parts first.
But the mechanics needs to remove your disk rotors if it needs to be refaced in a machines shop... this may take half a days work. About 2 hours in the machines shop, removing, and replacing, repacking the bearings and replacing the pads maybe about 2 hours also.
There's a shop called GLYCO - near Cecilles or BF Resort... they also have mechanics there - I think. It's actually an easy thing to fix. Medyo madumi lang - If I am only free - I will gladly volunteer to fix that myself. :-)
- Oct 2009
- 14
November 1st, 2009 12:08 PM #17
Tsikot Member Rank 4
- 1,842
November 2nd, 2009 02:34 AM #18Some brake pads have what you call wear indicator, some indicator naman is nasa Rotor na, wala sa pads, pag naubos na pads mo sasayad na iyan sa rotor at mag isisqueak, the squeak will remind you na pauboas na ang pads and needs to be replace
Now kung after mag change ka nang brake pads na bago at nag squeak pa din, maaring yung rotor mo is upod na. Kaya pag nag brake ka iingay na dahil sa tiny vibration because of gap created by wear on your rotor and pads
- Oct 2009
- 14
- Apr 2009
- 533
November 3rd, 2009 10:06 AM #20make sure lang you buy OEM or other brands na mahusay din otherwise sayang lang papalit.
sabi ng mechanic ko meron daw mahinang klaseng pads kaya maingay. ok daw
bendix.
Traffic!
