Results 1 to 4 of 4
- May 2010
- 14
June 13th, 2010 01:42 AM #1Guys yung steering wheel nyo ba nag-vivibrate as in you can here the vibration kapag naka-stop? "Stop" I mean nakaapak sa brake and nakashift-D sa automatic tranny.
June 13th, 2010 01:59 AM #2
not really. i'm not an expert on these but my advice is to put your gear in N when not moving, dahil nakaengage tumakbo ang makina mo kapag pinipigilan mo ng preno. like in m/t you don't leave it in 1st gear while stepping on the clutch habang nakatigil diba you put it it neutral.
June 13th, 2010 02:06 AM #3
there would be some vibration but should not be excessive.
if the vibration is excessive, try having the engine checked. Chances are it would only need either a good tune up or a throttle body cleaning to getting back to normal.
...and also have the engine mounts checked too.
- May 2010
- 14
June 13th, 2010 05:02 PM #4Thanks for the advices guys.
I forgot to mention that the vibration happens when I'm not holding the wheel. Wala naman kapag hawak na.
Monk-owned R53
