Results 21 to 30 of 32
February 24th, 2013 07:03 PM #21
pinaka madugo will be the suspension and steering column, price range malamang sabihin ng mga mekaniko mahal ang piyesa nyan kasi Honda pa-estimate nyo muna sir then palista nyo un parts na kailangan then kaw na mag canvas para may idea ka bago pagawa,pero try nyo muna un murang remedy which is un rotate and wheel balance baka dun palang solved na
- Apr 2009
- 429
February 24th, 2013 08:32 PM #22
- Jul 2003
- 573
February 24th, 2013 09:55 PM #23I believe the car steering starts to vibrate at 100kph ? Is that true?
Do you feel that the whole front member of the car vibrates? You have to very observant
so the diagnosis and fix can be done with minimum parts replacement and cost.
October 31st, 2014 06:19 PM #24
i have the same problem. steering wheel starts to vibrate at 80-100kph tapos mawawala sa 120kph. i'll be changing front tires soon, sana ma solve na yun problem.
October 31st, 2014 06:51 PM #25
Top 3 things to check kapag ganyan
1) wheel balance
2) wheel alignment and camber
3) shock absorbers
November 8th, 2014 02:32 AM #26
November 10th, 2014 02:31 PM #27
^ suspension parts needs visual inspection sa shop through lifter.
Kung shocks, simple test is itulak ma pababa sasakyan... Kapag hindi ka nahirapan pababain and biglang nag bounce yan may konting problem na. Kung oil type shocks mas madali through visual inspection kasi makikita mo tagas nung oil sa shocks mismo...
Sent from my Windows Phone 8 using Tapatalk
November 11th, 2014 11:50 AM #28
- Jul 2015
- 1
July 27th, 2015 01:01 PM #29
i have the same problem about a week ago... i have done some research here is what i got.
Top 5 Reasons Your Car Is Vibrating - HowStuffWorks
as it turns out the culprit is the rack end and tie rod...
my pinion also have a busted oil seal...
got it fix at around 15k plus.
July 27th, 2015 01:23 PM #30
vibration at certain speeds is usually caused by dynamically imbalanced tires. bent wheels, worn out tires, loose steering components (tie rods. loose rack and pinion assembly mounts, worn out wheel bearings) but believe it or not: dragging brakes will cause these symptoms.
