Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 51 to 60 of 93
    #51
    i can't seem to download the video.
    but i guess, the rack has to be centered first, before the alignment is performed.
    Mar 2007
    #52
    I still have my problem. Although lessened na. Changed all bushings and suspension related parts but still, nandyan pa rin. Ano kaya next ipatingin?
    Jan 2019
    #53
    Quote Originally Posted by box_type View Post
    if you notice in the video magkaiba talaga turning degrees ng right and left wheels, so I guess hanggang dun na lang talaga turning point ng wheels mo? watch mo raw yung next video nya gagawa sya ng custom kits para mas sharper daw yun turns...
    Hindi sir, before rack change, okay yong right turn, means mas less na turn niya ngayon as before. Anyway checheck ko muna, sana may ibang cause, like may bracket or something labg na mali nailagay kaya may tumatama. If wala, check ko yong rack limiter na nasa video, baka meron nga nakalagay sakin. thanks sir.
    #54
    Quote Originally Posted by suysuy View Post
    Are you the first owner of the car?
    I was thinking baka may previous accident damage. Kapag hindi na pantay ang chassis ganyan ang usual symptoms kahit anung palit at adjust sa suspension ayaw talaga tumino.
    Mar 2007
    #55
    Yup first owner. Never been into an accident. Naging ganito na siya nung nagpalit ako ng lower arm bushings left and right. Hmmmm
    #56
    is it possible that, when they replaced the bushings, they failed to center the rack before aligning the wheels?
    #57
    OEM bushings? Replacing the whole arm might be the trick.
    #58
    rack doesn't need centering. its pre aligned for the steeeing shaft.
    Mar 2007
    #59
    Genuine kia bushings. The whole arm costs an arm and leg. Baka ndi maayos sayang lang pera. There might be something that is causing this. Disc brakes and calipers were already checked. So hindi siya issue sa brakes.
    There is something loose when you apply the brakes, it changes the steering angle or the suspension shifts. But im already running out of ideas kung alin sa ilalim ang need pang tingnan
    #60
    Mukhang may mali sa pagkabit ng rack and pinion mo. Hindi nga centered yan kaya bitin sa kabilang side ang turn.
    Sent from my SM-G965F using Tapatalk
Steering wheel alignment issue
