Results 1 to 7 of 7
December 30th, 2009 10:22 PM #1
Good Evening sirs! I have a '97 Lancer.. Already undergone a major repair of its suspension last year..
I just noticed this past week that the steering seems stiff than usual.. What are the things that I should check for deficiencies? I have a manual but it is for the '96 model.. By the way, the steering system has not been replaced ever since the car was purchased way back in '97 and the km reading is 81k..
Will appreciate your reply about my concern, thank you!
December 30th, 2009 10:53 PM #2
Can you elaborate a bit more?
Is it stiff in a way that it seems that the power steering (if equipped) is not working?
Or does it fight steering input whenever the car is going straight?
December 30th, 2009 11:37 PM #3
December 31st, 2009 12:07 AM #4
When you said that your car received a major suspension work, what was fixed/replaced? They may not have returned it back to spec.
Alignment may also be off. Caster settings will have a great deal of influence on steering stiffness.
If it's a power steering problem, do you feel any difference in stiffness between when the engine is running and not?
December 31st, 2009 05:57 AM #5
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 3rd, 2010 03:04 PM #6check steering fluid if at proper level.
check the belt if it is snug enough. if it is, turn on the engine.
while in neurral, rev the engine to about 3K then turn the steering wheel left then right. if revving the engine makes the power steering work, you may have some problem with the pump. if not, pump is ok. look for other problems.
January 4th, 2010 07:10 AM #7
most likely either of these lang 'yan..
1. power steering fluid
2. high pressure hose leaking causing fluid loss
3. pump belt (di ko sure kng belt yan o pump)
usually yun hose starts leaking pag luma na.. pag maluwag yun belt it shows what you described when turning.. minsan meron pa squeaking noise..
