Results 21 to 30 of 37
- Sep 2008
- 630
- Aug 2012
- 2,767
January 15th, 2015 03:41 PM #22For comparison:
Mazda 6 Service Manual
Brake pedal free play = 0-3 mm (0-0.1 in)
Pedal-to-Floor clearance (With Pedal Depressed) = 68 mm (2.68 in)
Toyota Camry Service Manual
Brake pedal free play = 1-6 mm (0.04-0.24 in)
Pedal-to-Floor clearance (with Pedal Depressed) = 70 mm (2.76 in)
January 15th, 2015 09:24 PM #23
January 15th, 2015 09:57 PM #24
Aside from master cylinder and vacuum brake booster replacement, was there anything else replaced or done?
January 16th, 2015 01:18 PM #26
oo..mas advisable talaga na palitan as a set or kung seal replacement lang e wag galawin ang pushrod. karamihan kasi ng mekaniko inaadjust yung pushrod under the dash. hindi nila alam na self adjusting naman halos lahat ng drum brakes (provided na operational ang parking brakes).
pero kung hindi as a set ang palit gaya ng ginawa ko e baka makatulong etong thread na eto: Brake Job DIY - PinoyHandyMan Do-It-Yourself Community
January 16th, 2015 02:28 PM #27
January 16th, 2015 04:09 PM #28
i think you have installed an overly sensitive brake booster or feather trigger booster. what was wrong with the old booster anyway? if the booster does not have vacuum leak nor damaged in any way, try reinstalling it. just make sure you have 1 mm clearance between the cavity of the primary piston and the push rod at fully seated position. there is a brake booster push rod measuring tool for this. but in its absence, you can try to extend the push rod out forward lightly, then, use the master cylinder to reseat it. move the master cylinder out of the way and with your finger, push the booster push rod in, it should move in or retract about 1 mm.
https://www.google.com/search?q=brak...ap%3B731%3B289
- Apr 2009
- 429
January 16th, 2015 05:25 PM #29or you did not bleed your brake system adequately. Did you bleed your primary master adequately before re installing the fittings for the front and rear brake lines? afterwards, did you bleed the 4 corners starting from the farthest wheel then lastly the nearest wheel to the primary master?
I prefer not to touch the push rod between the hydrovac and the primary master in any way. Once you touch this without the proper measuring tools, you mess up your brake system. guaranteed.
You can, however, adjust the pushrod between the brake pedal and the hydrovac....
January 16th, 2015 05:58 PM #30
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
