Page 10 of 15 FirstFirst ... 67891011121314 ... LastLast
Results 91 to 100 of 148
    Aug 2004
    #91
    A compression test tells you whether your cylinders are fit... in other words, if the pressure in each cylinder as they move through their power strokes is similar or the same, the engine is healthy. If one cylinder has low pressure, it's probably leaking air, either through the piston rings or through the valves.
    In such a case, a leakdown test will tell you which way the air is going.
    Aug 2007
    #92
    Sir meron specific equipment na ginagamit yan na available in any talyer?
    For city driving ok lang ba mineral oil na castrol or meron mas ok na brand?
    Is it true na yung vvti na altis maselan daw sa langis na kailagan synthetic or sales talk lang sa casa?
    Thanks
    Jun 2006
    #93
    Quote Originally Posted by suv View Post
    Thanks
    1. They use a compression tester.
    2. Ok lang castrol mineral oil. Just stick with the known brands and you should be ok.
    3. Sales talk lang ng casa yan.
    Aug 2007
    #94
    Thanks.....Sir yung mga shell, petron lang ba complete ang mineral oil in any viscocity? Kasi Castrol ang offer 20w50 lang...
    Jun 2006
    #95
    Shell may 15w40 red bottle and 20w50 yellow bottle. Caltex 20w50 only. Castrol, parang may nakita akong ibang viscosity sa True value. Imported parang 5w30 yata. Di ko kabisado ang sa Petron. Try mo website nila.
    #96
    petron race synthetic oil 5w-40
    petron rallye, touring,extra ay mineral oil
    Aug 2007
    #97
    Kaya ba puro 20w50 available sa pinas eh dahil yun ang bagay sa climate dito?
    Kasi sa manual information ng Civic eh iba ang recommended na viscocity....5w30 ata....Pero sa synthetic lang usually available....eh ok na ako sa mineral......
    So pwede na yung 20w50 or kailangan ba talaga sundin ang manual? or depends sa climate ng bansa?
    Tapos nagpareserve na kami 2007 crv.....nabasa ko sa forum sa ibang bansa ang recommend daw eh 5w20.....grabe nipis naman nun....pwede ba yun sa pinas? eh wala pa mineral oil na ganun...
    #98
    Quote Originally Posted by speedyfix View Post
    flakez, you ncan contact them here: 818-52-98, 752-71-73, email: customercare*orangeperformance.com or dominique*orangeperformance.com
    edtf, what do you mean a diesel test?
    SIr, I meant wala bang test for oils used for diesel engines? OR puwede rin ba gamitin those oils for diesel engines? Thanks
    Nov 2003
    #99
    suv, the thickest you should go is a 40 viscosity for a stock engine. it's probably sales talk that maselan yung vvti ng toyota kaya kelangan synthetic. the way they should sell it is telling you more of the benefits of better quality oil rather than telling lies about the engines in their own cars. don't use a 50 viscosity if that is not recommended.
    edtf, well in royal purples case the 15w40 oil is specifically formulated for diesel engines. it also has the API diesel certification. not sure what other test you need.
    Aug 2007
    #100
    Speedy meron kayo branch or sister company in araneta ave, banaue or quezon ave?
Shocking truth about Oils!
