Results 141 to 148 of 148
March 12th, 2011 08:15 PM #141
A wala pala dito. Meron nga kasi ako nakita sa website ng RP, kaya nagtanong ako kung meron. Pasyal na lang ako dyan sa shop nyo sir speedyfix kapag nagawi ako ng manila. Thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 13th, 2011 07:43 AM #142is the 2.0 turbo or n/a. for n/a models you can use as thin as 5w30 oil. for the jdm turbo models i would suggest either 10w40 or 20w50 depending on how you drive. thicker oil for more track oriented use.
kkreuk18, sure no problem. we have the complete lineup of oil... yung oil filters lang wala.
- Jan 2010
- 107
March 13th, 2011 03:59 PM #143[quote=speedyfix;1698832]is the 2.0 turbo or n/a. for n/a models you can use as thin as 5w30 oil. for the jdm turbo models i would suggest either 10w40 or 20w50 depending on how you drive. thicker oil for more track oriented use.
Non-turbo po. Will change to 5w30 oil asap. Many thanks po.
- Nov 2003
- 3,849
- Apr 2016
- 9
April 2nd, 2016 10:09 PM #145
1st digit = viscosity of the fluid at cold temp.
2nd digit = viscosity of the fluid at 100 degrees celsius. (32 deg sa pinas ang init na 100 pa kya)
Viscosity = measure of its resistance to gradual deformation by shear stress or tensile stress = kumbaga sa sipon ung lapot. In essence mas malapot ang 10w kesa sa 5w.
- Jul 2015
- 9,584
April 2nd, 2016 10:24 PM #146
- Jul 2015
- 9,584
April 3rd, 2016 09:39 AM #148
There are new findings that a 10W30 with yield better engine performance.
Monk-owned R53
