Results 1 to 5 of 5
- Aug 2004
- 223
September 12th, 2004 07:22 AM #1sir tulong naman. after nun bagyo nag outing kami with frends going north then ang hirap ng daan kasi butas-butas na yung daan(malalaking butas). pag dating ko dito manila may naririnig na akong tunog galing sa ilalim. pag nakahinto ako at try kong alugin yung body ng auto may naririnig akong ingay sa ilalim sa may malapit sa torsion bar. tanung ko po mayrun po bang greasing area sa may torsion bar ng isuzu fuego(4x2)? or any greasing are sa under chassi or sealed ba lahat eto?
September 12th, 2004 03:44 PM #2
Malamang po nailusong nyo yan sa baha. Medyo naglalangit-ngitan ang bushings (from torsion ends, anti-sway bars and on to the links). One cheaper way to do is spray used oil, from your gasoline service station, on all bushings underneath to maintian lubricity.
A more complex and money draining solution is to have all the bushings removed and re-greased, if applicable.
- Aug 2004
- 223
September 13th, 2004 01:45 AM #4ok hirap pala mag re-grease ha. anyway, eto ang ginawa ko kanina. bumili ako kanina ng diesel and halo ko ng konting oil then spray ko sa ilalim sa torsion bar etc.. as of kanina after yung spray test drive ako then ok na konti siguro. obserbahan ko uli tom. sana di na bumalik un
September 13th, 2004 07:03 PM #5
Babalik din po in due time na ma-wash out ulit ang oil sa ilalim. Iwasan nyo na lang dumaan sa flooded areas kung maari. Then you'd have to repeat the same process and spray those parts again.
What vehicle and what's your budget?
