Results 21 to 29 of 29
October 8th, 2005 04:13 PM #21
I never knew "issue" pala ang pag repair ng gulong. Ako, madalas ma flat. Lahat na yata ng gulong ko may repair. never had any problems naman. Yun lang nga, basta wall ang butas, di na daw pwede.
October 9th, 2005 07:18 PM #22Originally Posted by SeminaristaKuno
October 9th, 2005 09:12 PM #23
Ang tamang pagrepair ng tire ay yung pina patch lang, huwag na huwag ipaluto yung gulong niyo, hihina ang threads nito.
October 10th, 2005 08:08 AM #24
Nung masira ang sidewall ng gulong, I had it repaired. But I used it as spare only. Fortunately, hindi naman ako na-flatan. Nung magkaroon ng budget, I bought a new one.
- Aug 2003
- 9,720
October 10th, 2005 12:37 PM #25SeminaristaKuno
May flat piece of metal mga 3mm wide na naka-baon sa tread ng tires ko. Tanggalin ko ba sya or hintayin ko na lang baka mababaw lang? Di pa naman ako nawawalan ng pressure.
knock on wood, been using the patched tire for months now. so far so good B)
February 24th, 2006 01:52 PM #26
the general rule to follow when having your tire vulcanized in those mom and pop vulcanizing shops is always use cold patch to fix the tire. wag nyo paluto, magooblong lang ang gulong.
February 24th, 2006 02:01 PM #27
[QUOTE=SeminaristaKuno]May flat piece of metal mga 3mm wide na naka-baon sa tread ng tires ko. Tanggalin ko ba sya or hintayin ko na lang baka mababaw lang? Di pa naman ako nawawalan ng pressure.[/QUOTE
mas maige sa may vulcanizing shop mo na siya tanggalin para in case me singaw, tuloy gawa na. kung wala swerte
February 24th, 2006 10:32 PM #28
Pagawa mo na yan agad, xto. Wag mo nang hintayin maflat ka pa in the middle of nowhere.
February 25th, 2006 04:24 AM #29
sa mga nagpagawa nung sidewall damage, anong klaseng sidewall damage ba? yung isa naming tire kasi ng outlander, may bumutas ng sidewall niya, la sa budget ang new and since wala kaming spare technically, paayos ko siguro.
also, ok ba yung ginawa nilang repair?
