Results 11 to 17 of 17
May 14th, 2008 08:29 AM #11
sir blitzkin, hindi basta basta nasisira ang wheel bearing kaya baka hindi yan yung kakapalit mo lang na bearing. pwedeng yung kabilang side kase sabi mo passenger side lang pinalitan mo. merong wheel bearing na pwede i repack tapos meron din sealed wheel bearing na kailangan pressed in( baka kaya madami pinagpupukpok sa auto mo) depende sa modelo ng sasakyan.
May 14th, 2008 10:18 AM #12
Ako i usually change both left and right bearings when the need arises. Repack with grease (molybdenum sirs) and change the CV boots na lang din to be sure.
May 14th, 2008 07:35 PM #13
hmm ganon pala yun... another reason i know is when you have big and heavy rims, like 17.'s and up.
May 14th, 2008 08:23 PM #14
another reason is yung di balase ang gulong mo...
pag binaha/ dinaan sa baha--need to repack the grease lalo na kung yung tig-80 pesos lang gamit mo, pero kung yung synthetic water proff grease dont worry much
- May 2008
- 4
May 14th, 2008 10:42 PM #15salamat talaga sa mga input nyo sirs! mejo marami na akong nalalaman na reasons kung bakit nagkakaganito ang bearing.. ipapatingin ko to mga sirs baka sa weekend. update ko nalang thread natin kung anong nangyari.. sana repack lang para mejo makamura!
thanks ulet and more power to tsikot!
May 19th, 2008 12:22 PM #16
makikipost na rin po. tanong ko sana kun may remedyo pa yung boot ng wheel bearing kun maliit lang ang butas, yung butas mas maliit pa sa butas ng paper puncher. TIA
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 22nd, 2008 10:21 AM #17dapat hindi pukpok yan. it should be pressed out with a hydraulic press.
I hope they improve the interior a bit. The current is IMHO low-rent for the price.
2025 Nissan Kicks
