Results 41 to 50 of 69
May 22nd, 2008 08:04 PM #41
sir, same problem din po sa akin. what do you mean sa resurfaced? pina chrome mo ba? saan po and how much. salamat po in advance.
- Nov 2007
- 30
October 28th, 2008 11:04 PM #42Sir bka my ma advise kyo san maayos at magling at syempre mura n gmgwa ng ps. my leak din kc ung skin. dti patak2 lng ngyn sobrang lkas n. as in nauubos n ung ps fluid ko. how much po b cost nung s inyo?pra macompare ko lng s mpg tatanungan ko. ano b una kong pa check? oil seal? ung basic lng. bka kc mloko k ng mekaniko e. hehe. thanks.
October 28th, 2008 11:49 PM #43
i think sir pwede pa rebuild yan try mo dalin sa AER kasi TQA dun sila nagpapagawa.. rebuild lng ng rack shaft yan tapos check din yung 2 bearing nya sa loob.. kasi nag karoon ng scored yan or gasgas..
- Jun 2011
- 1
June 20th, 2011 11:28 PM #44good day mga sirs.
Hingin ko lang din po sana mga opinions niyo.
nagleleak din po kasi power steering ko.
I have already used a repair kit for the rack and pinion and had the rack resurfaced, this was about a month ago.
Pero when I checked two weeks ago napansin ko may tulo pa din sa left side pero yung sa right wala na.
I'm currently trying to assess the situation, kaso di ko na alam kung ano pa pwede ko gawin para matigil na yung tulo.
If wala na talaga choice at kailangan ko na magpalit, magkano po kaya aabutin yung rack and pinion assembly nang Honda civic 95 Lx.
TIA po sa mga magrereply, at salamat din sa tsikot.
- Jun 2011
- 163
June 20th, 2011 11:35 PM #45AFAIK a new rack in pinion will cost you an arm and a leg. Wait if it's just a month after, you CAN bring it back for a BACK JOB. Sometimes the seal / rebuild kit is just not properly installed, thanks to the mechanic, or the... just forgot what's it called... an internal part of the rack and pinion needs to be machined and buffed.
June 21st, 2011 01:01 AM #46
*patsz24
how much nagastos niyo paayos ng leak? ganyan din kasi problem ko. nung pagkaayos ng leak malapit dun sa resevoir ( sa power steering din ) parang hose yata yun pinalitan dun. lumipat naman sa rack and pinion yun leak.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 21st, 2011 07:37 AM #47steering rack repair kits may or may not work depending on the condition of the rack. better to get surplus pa or if you can afford it, brand new. new will be in the high 30-40k range for that model. for newer cars minsan nasa 50k range.
- Nov 2003
- 3,849
June 21st, 2011 10:02 AM #49easiest way to check is to call casa or an auto supply specializing in your type of vehicle.
June 21st, 2011 11:01 AM #50
Pero sabagay bihira naman masira yan so sa surplus nga mas maganda IMO. Mura pa eh.
Monk-owned R53
