Results 1 to 8 of 8
- Apr 2009
- 14
April 17th, 2009 05:14 AM #1hi po mga bossing. i have accord 96 exi. newbie rin po ako when it comes to cars.
however. i have 4 questions, i hope you guys can help me.
may nakikita po akong leak sa garage kulay pula po. Looks like ATF ( kasi napakita na po sakin dati ng mekaniko ang ATF fluid). * 2 different spots po. pina check po namin sa YOKOHAMA along sa commonwealth diliman quezon city malapit po sa MALVAR gen hospital. sabi po ng mekaniko sa RACK AND PINION daw po tagas. OVERHAUL daw po ang gagawin.
binigyan po ako ng estimate of 9,500 pesos.
question is ;
1. tama po ba ang estimation nila ng price of 9,500 pesos?
2. may masmababa pa po bang price na pwede ipagawa ang tagas? kung meron saan po pwede puntahan at sino po pwede hanapin?
3. kelangan po ba talagang ipa OVERHAUL ang RACK and PINION o may simpleng paraan po ba para mawala ang tagas?
4. (not relevant to the topic) nagpalit po ako ng upper ball joint, magkaiba po ba ang lower ball joint sa upper ball joint?
ok naman po ang pag liko wala naman po bigat (steering)
- Sep 2007
- 215
April 22nd, 2009 08:57 AM #21. the estimation is a bit expensive .... labor is about 1800 for accord and the repair kit is about 1600 - 2000 original, 120 for the power steering fluid
2.look for me reggie banawe auto supply ...7120115
3.depends on the tagas pero kung minimal lang naman pwede huwag mo pagawa muna if you want cheaper i could recommend you near banawe pero you have to talk to them how much
4. yes magkaiba yung upper and lower balljoint
kung okay naman ang liko dahil may powersteering fluid ka pa ... kung maubusan yan uugong yan
- Apr 2009
- 14
April 22nd, 2009 11:46 PM #3ok sige po boss reggie, maraming salamat po ulit. sa katapusan ko po dadalhin jan. tawag muna po ako para makausap ko rin po kayo. maraming salamat po ulit
April 23rd, 2009 08:12 AM #4
mahal yan sir.. tanong po kayo sa iba may mas mura at maayos din ang gawa nila..
- Aug 2007
- 13
April 11th, 2010 08:26 PM #5technismo san ba yang alam mo? i had the same problem with my 96 civic lxi.
April 15th, 2010 11:11 AM #6
Sir reggie, magkano overall cost ng repair ng rack and pinion ng 96 honda city? Me leak kasi everytime na todo kabig.
- Apr 2007
- 97
April 21st, 2010 07:47 PM #7Mejo mahal talaga labor nyan kasi madami babaklasin. More or 3.5k magagastos mo dyan including parts and labor.Make sure na magpa align ka din ng gulong sa harap after baka di pantay manibela mo (Might be a case to case basis)
- Sep 2007
- 215
April 23rd, 2010 06:54 PM #8hello ... civic will cost you about 3500 nga ... kasi mga 1800 + yung kit and mga 1200 plus yung labor .... pero ndi na ako tumatangap ng honda ... kasi maselan madalas back job
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
