Results 1 to 7 of 7
June 3rd, 2004 05:15 PM #1
what tire pressure will i follow?
the one indicated at my GT3 tire (35 psi) or
dun sa nka indicate sa door ng car ko?
i also checked the goodyear phils. website, 35 psi rin ang sinasabi. at present, nasa 30 lang ang tire pressure niya.
takot naman ako ma-oblong kapag ginawa kong 33-35.
advice naman please.
thanks!
- 10,620
June 3rd, 2004 05:26 PM #2ok naman siguro sa 30-33 psi yan pre
remember kapg uminit ang tire plus 2 pis pa yan.
- Oct 2003
- 74
June 3rd, 2004 07:21 PM #3potenza G3 din tires ko 195/55/r15 25psi lang tire pressure ko...... tagtag kasi pag 30 psi.... 5 months n gulong ko ok nmn walang problem
Tsikot Member Rank 3
- Dec 2002
- 636
June 4th, 2004 06:28 AM #4Follow tire pressures on door jamb or car manual assuming you're using stock tire size.
- May 2004
- 12
June 4th, 2004 08:41 AM #5bossing, tingnan mo yung lapat ng thread pag nag inflate ka ng tires mo. hindi pantay ang kain ng thread pag under or over inflated. dagdag ka lng ng pressure pag dagdag ka ng load.
June 4th, 2004 12:45 PM #6
you can look at your tire to find the max load and pressure. divide max load by max pressure to find max load per psi. compute from there how much psi you will need for the weight of your car plus its normal cargo. the difficulty is finding the ratio of the car's weight between front and rear.
- Feb 2003
- 618
June 5th, 2004 09:34 PM #7follow the recomended tire pressure para ok ang ride....and remember to check your tire pressure at least once a week ...
any feedback for America Lumina Nano Ceramic ? which better between Sunblock Ceramic vs Lumina...
