Results 1 to 2 of 2
- Jul 2007
- 46
February 29th, 2008 07:31 AM #1Hello mga tsikoters, need a little help, when i turn steering wheel left or right may naririnig akong clicking na may slight vibrating sound,before,PS had a leak so CASA replaced the hoses and o-rings that involves it,so far wala ng leak its all good but the sound is still present.It gets very pronounced kung nasa between 10 to 20 kmh speed ko but kung naka standby lang while engine is turned on, wala ako naririnig, napa check ko po to sa CASA, bagong replace na po yung boot front inboard kase sabi nila may leak na raw, pero nangyari nato even before replacing the boots. could this have something to do with the PS fluid? cause i think i haven't flushed out the fluid or bleed out any air yet, i only added up steering fluid before since nagiging kulang siya dahil sa leak. please need your suggestions..Thanks..
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
