Results 11 to 20 of 20
April 26th, 2007 03:18 PM #11
Tumitigas? Baka dumudulas yung belt sa pulley. Experience ko kapag dumulas yung belt sa pulley, yung steering feel tumitigas. Pero the belts look OK upon inspection.
April 26th, 2007 03:25 PM #12
Sir, how long has it been since you last changed your PS fluid? Kung more than 3 years na, suggest you do it asap. Kung nagpalit ka na ng ball joints at yung nilagay mo ay may fittings, magpa greasing ka na rin. These will do a lot of help and hopefully solve your problem. If orig pa, palitan mo na. I agree with mbeige. Kung lumalangitngit yung belt mo or may times na malambot-matigas-malambot-matigas yung steering mo, signs of belt slippage na yan. Mbeige said it correctly, it may ok upon inspection. Check the underside of the belt (the one that gets into contact with the pulley). Malamang puro crack na yan.
Also, check mo yung gearbox mo for leaks.
I had a problem with my spindle some years back. Bumaluktot dahil bumigay yung wheel bearing ko, right side. Almost two weeks ako tumatakbo na halos 45 degrees yung right tire ko. Newbie lang kasi ako nun sa motoring world kya d naagapan agad. Maraming machine shop dyan along alabang zapote road that can help you with that.
HTH
April 30th, 2007 08:36 AM #13
April 30th, 2007 08:41 AM #14
Bro any recommendations na autoshops na may machine shop na & wheel alignment? preferably makati, taguig, pasig area? ung mga goodyear servitek ba ok dun? or mahal??
May 2nd, 2007 01:29 PM #15
Sir,
Mga 5T ginastos ko that time. Zafra LP ko pinagawa. May contact sila na machine shop and they did the alignment that time. AFAIK, there is no machine shop with alignment service. Try searching for a shop that does fabrication/modification. I am of the opinion that these shops have the necessary machines needed to fix your problem. I think we have a thread here at tsikot where the members have their rides serviced. Hope that could be of help to you.
PEACE !!!
November 26th, 2007 06:43 PM #16
Up ko lang ito.
Syuryuken, naayos mo na ba ang power steering mo?
Yun PS ko kasi mabigat pa rin. Naayos ko na ang pump. Bagong bearing, bagong shaft. Wala nang leaks. Kahapon pinalitan namin oil seal sa steering unit. Wala na ring leak. Drain ko din lahat ng oil tapos pinalitan ko ng bagong ATF (Castrol TQ-DIII --- Dexron III daw ito). Pero mabigat pa rin. Ano kaya problem nito?
Tsikot Member Rank 5
- Nov 2003
- 3,849
BANNED BANNED BANNED
- Jul 2003
- 2,267
November 26th, 2007 10:27 PM #18
check mo kung tama yung pressure ng fluid na galing sa pump. kahit palitan mo yung parts ng pump, kung busted na ito, ndi na ito magbibigay ng tamang pressure. yung pressure range pwede makita sa repair manual. now ur problem is kung papaano mo ito gagawin kasi meron special tools na ginagamit to check the pressure from the pump. mybe you ask the casa.
another option to check kung pump pa din ang problem is to install a spare pump na alam mong ayos. or to go to surplus shop. kontartahin mo na lang yung tao dun at sabihin mo ndi ka kasi sure kung pump ang problem so you need a spare pump to test. kung nagkaroon ng power assist using the surplus pump, bilihin mo na. kung ndi naman, wag mo bilihin kasi ndi pump ang problem. bigyan mo na lang konting pera yung tao for the abala :D
kung sure ka na ndi pump ang problem, you'll have to look at the steering gearbox assembly. mas complicated ito compared sa pump.
December 2nd, 2007 05:29 PM #19
up ko lang...
observation ko guys using an ATF Dextron III fluid, matigas talaga yung feeling ng manibela ko.
pero nung nagpapalit ako ng Power Steering Fluid mismo (STP ginamit ko galing carshow dun sa MOA) nagiba yung feeling ko, gumaan sya at nawala ugong.
December 2nd, 2007 09:09 PM #20
Salamat sa replies. Subukan ko muna ang cheapest option. Palitan ko ang Castrol TQ-DIII --- Dexron III with Dexron II or Besco ATF or any ATF. Check ko kung lalambot.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
