Results 51 to 58 of 58
September 30th, 2014 10:32 PM #51
September 30th, 2014 10:48 PM #52
Then make sure to put genuine Honda PSF when you get your "new" pump. Additionally, drain-replace when necessary to avoid dirty PSF circulating in your pump.
- Sep 2014
- 12
September 30th, 2014 10:54 PM #53This thread is really heaven sent! I questioned the mechanic kung pump na talaga. Sabi ko it could be another leak or baka need i-bleed. Binaba nya yung pump, may leak ang oil seal. Pinalitan na ng oil seal and it worked! Pero it's not that magaan parang dati. Pag-uwi ko sa Manila, I'll make sure na papalitan ng orig na fluid. Pero sabi ng mechanic di na din talaga tatagal yung pump. Madami na daw gasgas. Nakita ko nga din gasgas na talaga. I'll make sure to canvass na din sa banawe. Thank you sa lahat ng tumulong!
Posted via Tsikot Mobile App
- Aug 2012
- 2,767
October 1st, 2014 12:06 AM #54the pump can be tested without removing from engine using a fluid compression gauge. hindi lahat ng auto shops ay meron nito. the Honda casa for sure will have this but of course mas mahal din bayad.
according to CRV service manual, the fluid pressure should be:
with pressure control valve fully open = less than 213 PSI
if reading is above 213 PSI, check outlet hose and valve body
with pressure control valve fully close = at least 1,000 to 1,140 PSI
if reading is below 1,000 PSI, repair or replace the pump
if worn out na ang components ng pump, no use to salvage it since operation is already compromised. replace it as soon as possible.Last edited by red_one; October 1st, 2014 at 12:11 AM.
- Sep 2014
- 12
October 1st, 2014 12:36 AM #55*red_one can you recommend a shop that can do such? Btw, your inputs helped a lot. Thank you so much!
- Aug 2012
- 2,767
October 1st, 2014 09:06 AM #56wala ko alam na particular shop with P/S pressure gauge eh.
if mapalitan mo na ng Honda P/S fluid at mabigat pa rin ang steering, it would mean lower than 1,000 PSI ang pump pressure.
- Sep 2014
- 12
- Oct 2014
- 341
October 16th, 2014 12:28 AM #58Mga sir may tanong lang ako regarding sa steering ng mazda 3 ko. Kapag nagpapark kasi ako or umaalis sa parking parang nagsstop yung pagkabig ko ( parang sagad na yung manibela pero hindi naman ) pag nag step ako sa break. Then pag binitawan ko preno tumutuloy naman yung pagkabig.
Ano po kaya problem ? Meron power steering warning light yung mazda 3 ko pero hindi naman nagwawarning light.
Because most off-the shelf electricals and accessories (headlights, infotainment, horns) are still...
Hyundai Philippines
