Results 21 to 30 of 58
- Aug 2013
- 112
January 27th, 2014 06:36 PM #21actually problema ng galant ko rin yan TS. Although hindi naman sobrang bigat, parang in between ng manual steering ng owner jeep namin and my other car (rav4). I remember driving our sentra old series 3 and singkit glxi, parang anlayo ng lambot nya sa galant ko.
Right now I'm getting my rack and pinion fixed dahil may tagas. Although hindi ako sure if this will help the steering to be soft and easy again.
- Mar 2014
- 1
March 8th, 2014 11:21 AM #22power stering problem altis 2008 ..since nung bagong bili sya makunat steering nya malambot pa yung lancer na hotdog..dka mka mani-obra ng isang kamay..ganito ba kahina talaga PS ng corolla? wala namang strange sound pag kaliwat kanan mo..no leaks, walang maluwag na bolt/hose..ecvrything is clean..test drive a ford focus lately tang ina ang lambot and direct ang response! kung may pera lang ako pamimigay ko na tong altis ko eh..
PS: pati clutch ang kunat apapkan..wala ring tagas seal sa master and slave cylinder ..binuksan and nilinis ko super smooth ang wall..no sign of scratch or what so ever..nasa clearance lahat..
- 52,693
March 11th, 2014 10:39 AM #23clarification: you bought the car brand new back in 2008, and its wheel and pedal were already that difficult to operate even then?
or, this car is a recent acquisition, pre-owned..?
if the latter, i would have the transmission checked. the manibela naman,,.. dunno. no experience there.
- Mar 2014
- 2
March 17th, 2014 06:12 PM #24Matigas masyado yun steering to the right. And parang wala nang power steering at all. Sobra tigas. Pro while driving no problemo naman. Compared to other pajeros my friends have mas mabigat yun sa akin.
Esky Heli Parts
July 13th, 2014 09:34 AM #25
hijacking this tread if you all dont mind...having almost the same problem with my corolla BB gli...its been a week already...the steering is so heavy kapag nakahinto pero super lambot naman kapag tumatakbo...theres a humming sound even when im not doing anything sa steering wheel.maynakikita akong tagas sa hose na nakaconnect mismo s rack napaayos ko na ito dati pero bumalik ulit.replacement na yung rack and pinion ko.pinacheck ko sa mechanic kung ano problema ang sabi eh palitin na raw yung rack and pinion ko.i was thinking pano nangyari un e 3 yrs pa lang yung rack.i had second thoughts so ipinacheck ko sa ibang mechanic ang sabi eh yung steering pump ko ang sira..so which is which ??alin ba sa 2 yung possible na sira kasi ayoko basta iapagawa tapos di naman pala yun yung sira madodoble lang yung gastos ko.need your expert advice on the matter bago ko ipagawa..
btw paano ko ba malalaman kung sira yung rack and pinion ko?dkc binigyan ng malinaw na explanation nung mechanic kung paano nya nasabi yun yung sira..even nung pinalitan yung previous rack ko eh di rin malinaw yung reason...si erpats ang nagpagawa previously since nasa labas ako ng pinas nungtime n supposedly nasira yung former rack ng auto ko.
- Jul 2014
- 1
July 17th, 2014 02:33 AM #26any recommended shops in the south for power steering problem? las pinas area sana. nagleleak yung ps fluid. pinalitan na ng oil seal before kaso bumalik yung problem. baka kelangan palitan na lahat. kung me kilala din kayo na homeservice. and sana idea kung magkano estimate na total gastos ko for repair. thanks.
July 17th, 2014 05:55 AM #27
Had some issue with my Mirage G4.
Kakabili ko lang last May 2014.
Me times na makunat yung manibela.
Twice ko na dinala sa casa and nung una sabi tire pressure daw. Last week nilagyan lang daw nila ng lubricant pero ganun pa din. Nung una ko ginamit malambot nman.
Any advise mga masters?
Sent from my iPod
- Jul 2003
- 573
July 17th, 2014 04:12 PM #28Try the Shell Customer Cradle across Perpetual Help Hospital, Pamplona. Medyo mataas nga lang labor, pero kumpleto naman tools at maayos and work.
July 18th, 2014 11:07 AM #29
magkano labor po?
pero sayang kasi covered pa ng warranty yung sasakyan...
Sent from my iPod
- Aug 2014
- 2
August 16th, 2014 07:33 PM #30Hi,
Inquire din po ako regarding sa power steering problem, honda city 2000 model ng car. Dinala ko sya sa Pitstop nakita nagleleak yung ATF, power steering fluid daw po. ang advice ng nag-check na mekaniko, kelangan na daw po palitan yung power steering kit kaya lang wala sila nun so dalhin na lang daw sa honda service center. pagdating sa honda service center, kelangan daw po palitan gearbox. sobrang mahal ng gearbox dun. baka po meron kayo alam murang gearbox or where can we check the power steering.
Thanks!
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
