Results 11 to 20 of 20
BANNED BANNED BANNED
- Jul 2003
- 2,267
June 28th, 2007 08:30 PM #11kung meron unsual sound like hizzing or ugong, better check for leaks anywhere in the power steering system. check mo din yung rubber boots sa steering rack kung may excessive oil. kung may leak and you have the money, pa repair mo agad. leaks can be from the pump, hoses or the gearbox (steering rack). lahat naman yan kaya irepair basta walang tama or upod yung metal parts.
yung sa akin mejo napabayaan kaya hanggang ngayon eh nagpapaayospa din (see other thread)
June 29th, 2007 02:51 AM #12
tanong na din ako about power steering, masama ba ikabig yung steering wheel while engine off?
June 30th, 2007 02:34 AM #14
June 30th, 2007 11:11 AM #15
filled up naman. pero weird talaga. kapag unloaded (jacked up) yung gulong
ang lambot at walang ugong. pero kapag binaba na at nagtouch na yung gulong sa ground, dun na umuugong hehehe anu kaya un?
June 30th, 2007 11:48 AM #16
ganun talaga yun pre. wala naman force na nagka-counter sa steering mo pag jacked up yung wheels eh.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 4th, 2007 12:50 AM #18
Like I said bleed your power steering to remove air on your system.
How to bleed?
Make sure your reservoir is in max level of fluid w/ cover on. Start your engine (idle) steer your steering wheel lock to lock from left to right for 4x on each side or until that annoying sounds are gone. Also check your belt for tension. Push down your belt (center between the the two pulley) w/ your finger your belt must play at least an half inch. If your belt is to loose or to thight make necessary adjustment.
July 4th, 2007 12:41 PM #19
baka madumi na yun gearbox or rack and pinion steering. Or may tama na yun pump. Kung walang leak pull down the gearbox and clean or replace the inards with a repair kit.
- May 2004
- 19
July 4th, 2007 03:56 PM #20Guys please help with my problem kung saan ko pwede ipagawa ito kc yung may laro yung power steering ko, db dapat wala pag nakahinto... tapos under steer sa kanan unlike sa left mas naiiturn ko na todo sa right parang kalahati lang...
Please recommend me the shop na pwede kong ipaayos ito sa south sana... FYI pina ayos kona ito sa Cruven Sucat pero ganun parin, ang dami ko naman pinaayos sa kanila like full front suspension.
Your help is greatly appreciated. thanks a lot
mom loved the Ten Commandments. i also liked the two actors there, yul brynner and edward g...
Traffic!
