Results 41 to 50 of 51
January 5th, 2011 01:23 AM #41
Sorry to revive an old thread, but has anyone here seen the "Lucas Power Steering Stop Leak" product locally?
Otherwise I'll probably try the Cyclo nalang.
- Jan 2011
- 2
January 5th, 2011 09:24 AM #42Can I use this Cyclo power steering leak stopper sa honda accord '96 model? nasa hose yung leak eh. same as the other mga 1 week before ako mag lagay ulit ng ATF dati. ngayon abot 3 weeks kase minsan ko na lang din gamitin ngayon.
- Jan 2011
- 2
January 12th, 2011 08:21 AM #44Planning to buy this Cyclo, saan concorde kaya sure na meron? will drop-by at megamall later after office.
- Aug 2009
- 420
January 15th, 2011 11:57 AM #45ako din, may leak ung power steering box. lumalabs ung fluid if i ikot talaga ung steering, kung konti lang. hindi masyado. papaayos ko bukas. seal lang daw ung sira
January 24th, 2011 12:59 PM #47
I've already bought a bottle of Cyclo, but I'm kinda hesitant to use it yet.
Will this in any situation cause the power steering components to get damaged? Ok lang sakin hindi gumana sa pagstop ng leak, basta wag lang sirain yung power steering system ko! :D My car requires "Dexron type II" (or later) type of ATF/PS fluid..
Opinions please!
- Apr 2009
- 544
April 12th, 2012 11:59 AM #48Hi Up ko lang itong thread.
Para sa mga nakagamit na ng Cyclo PS Stop leak since 2006 okay na ba PS niyo? tumagal ba yung paggamit ng Cyclo?
ako naman used cyclo on my crosswind, yung leak sa ride ko mahinang mahina lang. its been 3 weeks now wala ng leak yung steering gearbox. bought it at Concorde for 379 pesos. I think for malakas na leak need na palitan or paayos sa
shop pero kung minor leaks lang like a few drops in a day, this might fix the problem.
need ko lang feedback sa mga nakagamit na dati.
thank you
April 12th, 2012 12:25 PM #50
You might want to try the MAG1 POWER STEERING FLUID WITH SEALER & CONDITIONER.
Seals & gaskets in older cars tend to dry out, harden & shrink, causing system leaks. Stop those leaks by adding a bottle of MAG 1 Premium Power Steering Fluid With Stop Leak when changing or topping off power steering fluid.
Benefits of Mag 1 Premium Power Steering Fluid With Stop Leak include:
Special 2 in 1 formula
Stops system leaks
Softens & conditions hardened seals & gaskets
Smooths & eases steering operation
This type of PSF will only work as long as it can close the gap.
Worn-out seals should always be replaced ASAP.
Daming issue ng SU7:grin:
Xiaomi E-Car
