Results 1 to 8 of 8
- Feb 2006
- 771
April 6th, 2009 07:36 PM #1mga sir,
medyo matigas po kasi yun power steering ko ,parang "pawis steering"nga dating e.
i noticed po na medyo natuyuan po kasi yung PSF reservoir ng fluid.kaso di ko alam gaano na katagal nawalan to kasi ngayon ko lang uli nagamit car e.
anyway ,nirefill ko siya ng PSF na STP brand yung red,to the required level kaso ngayon parang wala nangyari e parang ganoon pa rin matigas pa rin siya.
tama po ba yun nirefill ko lang sya without doing any bleeding?or bleed muna dapt?
any tips?or procedure how to bleed the PS fluid if kailangan sya bleed muna?
ok po yun mga belts nya !
btw ride po pala is Galant 7G
thanx
April 6th, 2009 07:53 PM #2
Check it immediately with a mechanic, baka madale pati steering pump mo and baka mag cause pa ng tear sa power steering rack mo. Malamang may leak yung rack bushing mo. You still can steer but matigas. Had it to experience on my Galant. nagbaon lang ako steering fluid papunta sa mekaniko, mag matigas na, karga agad.
- Feb 2006
- 771
April 7th, 2009 11:14 AM #4sir,
wala naman po leak yung P/S yung pump o kahit ano tubes nya e!
pag po ba nalagyan na P/S fluid automatic na lalambot uli steering ko or unti unti babalik yung lambot ng steering?
April 7th, 2009 11:42 AM #5
pagka refill mo ng PS fluid, paandarin mo ang makina at try mong steer left and right to bleed the system. than check mo ulit ang level ng fluid kung nagkulang dagdagkanalang ulit, repeat hanggang di na nagbabawas ng fluid, kailangan magiging magaan na ang steering mo pag ginawa mo ito,
- Feb 2006
- 771
April 7th, 2009 02:17 PM #6*sir raine,
sir nafill ko na yung reservoir ng fluid, at nadrive ko na rin sya for the this week , so far as i have observed ,slight lang na gumaan yung steering ko kaso parang di sya ganun kagaan e
pero as of now e di nman sya nagbabawas ng fluid e.
seldom po kasi to gamitin ung ride ko ksi lagi alis pinas e , mga 3 months pahinga tpos tsaka sya gamit uli ng mg 2~3 weeks tapos garahe uli kaya di ko masyado napansin na tumiigas na yung steering nya.
sa pumps ba wala masyado ilolook out as long di sya nagleleak d b?
April 7th, 2009 04:25 PM #7
Sadly, damage may have already been done when the reservoir dried up. The hydraulic power steering is a closed-loop design. It means that the fluid does not get consumed, burnt, or used up the way an engine would consume some oil.
That said, if the reservoir becomes empty, all that PSF went somewhere... most likely a leak that collected in the steering rack bellows. The bellows may hide the symptoms of a leak.
Here's a quote from: http://www.checkthatcar.com/data/pow...luid_level.asp
"[SIZE=2]Power steering fluid does not get "used up" - other than a leak, there's no reason that the fluid should be low. Fill the reservoir to the proper level and check frequently if you find it low. If it continues to be low, check for leaks and go see your mechanic. An empty power steering pump can be damaged very quickly and is costly to replace."[/SIZE]
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 10th, 2009 12:23 PM #8you have to find the source of the leak. hindi dapat nagbabawas yung psf.
Monk-owned R53
