Results 31 to 40 of 45
November 10th, 2007 07:06 AM #31
kaya ba DIY flushing ng power steering? meron bang parang drain plug?
- May 2007
- 6
November 12th, 2007 05:03 PM #32yeah pwede ba yun? atf din nalagay ko sa kin, gago yung sa gasoline station ok lang daw yun. sayang ah! pinaayos ko kasi mounting ng engine ko then after a week or 2 npansin ko medyo mabigat or matigas steering ko, lalo na sa reverse or parking. isip ko bka sa fluid ky anapabili ako.. mali pa nailagay.
November 13th, 2007 11:29 PM #33
update: i just purchased an OEM p/s return and a pair of local hose (small). the former was just a bended rubber hose. nothing special but the price. the latter was dirt cheap compared to OEM. 900 each compared to 130 a piece. DIY lang ang install nung small hose pero sa freelance p/s specialist ko pinakabit yung return hose. so far no leaks.
November 16th, 2007 09:21 AM #34
hi guys, semi-off topic tanong ko.
is it possible to install power steering in a vehicle, specifically sa minivan? if that's the case would you recommend any shop for installing such? thanks!
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 18th, 2007 10:34 AM #35if somewhere in the world that specific car came with power steering then just get those components and move it to your car.
but if wala talaga then you will have to fabricate lots of the parts.
- Nov 2007
- 132
November 18th, 2007 07:20 PM #36
- Aug 2007
- 72
August 19th, 2009 09:17 AM #37question po. i have a honda city exi 97 model.. the power steering fluid is now at minimum level... i am not sure where to buy the power steering fluid. i read from some thread here that i cant use any ps fluid for honda as it could cause damage on ps tank. please help po. TIA ;)
- Aug 2010
- 224
September 20th, 2010 06:23 PM #38Sa akin di ko alam kung saan ang problem.. basta napansin ko lang di na ganun ung power nya o parang nawala.. kasi pagliliko medyo double effort na di gaya dati na onting turn lang ssunod na..
Pero nung pinacheck ko sabi may problem na rin daw ung hose dapat palitan..
Lagi ko naman check ung fluid parang di naman nababawasan..
Ano po kaya talaga problem at solution?
Thanks!
September 20th, 2010 06:34 PM #39
September 20th, 2010 06:44 PM #40
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
