Results 1 to 2 of 2
- Nov 2008
- 30
December 28th, 2008 03:55 AM #1mga paps,napansin ko po pike ung gulong ko sa unahan pano po kaya gagawin yon?camber po kaya sagot dun?lec po pala yung oto ko.TIA
December 28th, 2008 08:16 AM #2
There are three angles to a vehicles alignment, camber, caster, and toe-in/toe-out
Camber is the angle from the top of the wheel to the bottom, when you lower a car, generally this angle will change dramatically, and while most vehicles have some adjustment for this (unless botom out). Now when you lower it the amount of adjustment needed is greater than factory specs will allow, therefore you'll need an adjustable camber kit, it will help you get your camber closer to specification, which will greatly help with tire wear and pulling.
Are you sure this is what you looking for? Or maybe your car just simply need an alignment.
Traffic!
