Results 11 to 13 of 13
August 19th, 2009 11:16 AM #11
i do my tire rotation atleast every 20k km, or pag pansin ko na na nauuna na maupod ang harap,
check out rotating your tires on:
http://www.carbibles.com/tire_bible_pg2.html#
August 19th, 2009 11:29 AM #12
If you use high performance street tires (H/P) on your pickup you should rotate every 10TKm, specially if you do a lot of (relatively) high speed turns. For medium compound tires 20TKm is ok.
A/T tires are useful in areas when you go on and off bad roads. M/T's are good for off road use but their mileage will suffer dramatically if you use them on paved roads, specially at speed. M/T tires (the good ones anyway) are made of soft compounds.
I use H/T tires because they are the most quiet, comfy and are great on the corners.
