Results 21 to 26 of 26
January 13th, 2004 07:55 PM #21
ngek ang mahal ah. pero truck naman yan. bakit yun bosing ang nag da-drive? :D
- 3,754
January 13th, 2004 08:58 PM #22alfred kakatawag ko.. mukhang na sira isang bearing ng gulong sa Fri nalang daw paki sabi kay Ferdie.. anyway papa tawagin ko din si misis kay ferdie para ma sabi nya...
ngayon lang na sira ang bearing coming from aoput garden going sa bahay... kukuha sana ng pera para bukas ehh nasira pa hehehehe friday nalang daw papagawa muna nila bearing
January 13th, 2004 09:00 PM #23
ruel:::kausap ko si ferdie ngayon2 lang. nakalimutan niya baka kailanganin ng extra pulley kung hindi pa double pulley ang makina. set na pala yon gearbox and PS pump pang Canter. The hose sa 1st ave na lang pa fabricate.
- 3,754
January 13th, 2004 09:07 PM #24natawagan na din daw ni misis sa Friday nalang daw dadalhin ang truck.. papa text ko nalang sa kanya ang engine model para may idea sya.. uhhh laki pala gastos pa lagay ng P/S
- 179
January 14th, 2004 09:10 AM #25is this a safe conversion? is it safer compared to a transmission conversion? can it be done to a van?
January 15th, 2004 08:26 PM #26
xox:::Yes, actually the replacement gearbox/pump will be from a Canter too. I basically hope this would be a bolt-on process. If the mounting/chassis should need drilling, a pipes/tube will be inserted to reinforce the chassis. If there would be any failure it would probably come from the RHD to LHD conversion itself.
