Results 1 to 7 of 7
    Good Day guys!
    nagkaron ako ng problema sa ride ko one time. umusok yung sa may gulong driver's side sa front. nung icheck ko sobra init ng mags ko sa front compared dun sa likod. pero mas mainit talaga yung nasa driver side kasi nalusaw niya ung axle boot eh. i replaced bearings tapos nagpalit ng brake pads. pero nung itakbo ko yung sasakyan uminit pa din un front mags. hope you can help me out with my problem. thanks guys!
    [SIZE="4"]REMINDER: do not post in SMS/TXT format when posting in tsikot.com[/SIZE]
    Quote Originally Posted by flame00x View Post
    Good Day guys!
    nagkaron ako ng problema sa ride ko one time. umusok un sa may gulong driver's side sa front. nun icheck ko sobra init ng mags ko sa front compared dun sa likod. pero mas mainit tlg un nasa driver side kxe nalusaw nya ung axle boot eh. i replaced bearings tapos nagpalit ng brake pads. pero nun itakbo ko un sasakyan uminit pa din un front mags. hope u can help me out with my problem. thanks guys!
    Check the brake caliper if the pistons are moving smoothly. Also check the caliper itself if it slides smoothly as well. Check the wheel bearings.
    thanks sa quick response. sorry medyo napamadali kasi yung pagkatype ko ng message..
    Given you have already replaced the wheel bearings, chances are your brake calipers are stuck up in some way or another. You can check by lifting the front wheel (with a jack) and give it a turn by hand.
    Aug 2004
    +1. It's almost sure to be a brake thing. If you use your brakes to do a lot of hard stops, they get hot. If they get hot too often, or if your discs are warped, it can cause caliper problems and brake sticking.
    When I still had my Sentra, my brakes were always a dull, glowing red by the time I got home at night.... ...my headers, too.
    Jul 2003
    the problem as it was stated occurs only on one side of the wheels. Hence I don't think it has something to do with hard braking or fast driving. I suggest that you bring your car to a shop and have your barake caliper serviced and overhauled. you can buy piston and caliper repair kit, once the problem has been identified.
overheat na mags??!
