Results 1 to 7 of 7
- Mar 2009
- 12
August 19th, 2009 11:12 PM #1Good Day guys!
nagkaron ako ng problema sa ride ko one time. umusok yung sa may gulong driver's side sa front. nung icheck ko sobra init ng mags ko sa front compared dun sa likod. pero mas mainit talaga yung nasa driver side kasi nalusaw niya ung axle boot eh. i replaced bearings tapos nagpalit ng brake pads. pero nung itakbo ko yung sasakyan uminit pa din un front mags. hope you can help me out with my problem. thanks guys!Last edited by flame00x; August 19th, 2009 at 11:41 PM. Reason: no texting
August 19th, 2009 11:22 PM #2
[SIZE="4"]REMINDER: do not post in SMS/TXT format when posting in tsikot.com[/SIZE]
August 19th, 2009 11:28 PM #3
- Mar 2009
- 12
August 19th, 2009 11:43 PM #4thanks sa quick response. sorry medyo napamadali kasi yung pagkatype ko ng message..
August 19th, 2009 11:47 PM #5
Given you have already replaced the wheel bearings, chances are your brake calipers are stuck up in some way or another. You can check by lifting the front wheel (with a jack) and give it a turn by hand.
August 20th, 2009 03:59 PM #6
+1. It's almost sure to be a brake thing. If you use your brakes to do a lot of hard stops, they get hot. If they get hot too often, or if your discs are warped, it can cause caliper problems and brake sticking.
When I still had my Sentra, my brakes were always a dull, glowing red by the time I got home at night.... ...my headers, too.
- Jul 2003
- 573
August 21st, 2009 06:47 PM #7the problem as it was stated occurs only on one side of the wheels. Hence I don't think it has something to do with hard braking or fast driving. I suggest that you bring your car to a shop and have your barake caliper serviced and overhauled. you can buy piston and caliper repair kit, once the problem has been identified.
Traffic!
