Results 31 to 40 of 42
- May 2017
- 2,099
July 18th, 2020 08:18 PM #31Salamat Bossing, pero nabasa ko na sa Tsikot yung negative feedback about Rapide, pwede ka pala ma-ban sa Tsikot kapag pumupunta ka sa Rapide... lol
RAPIDE FeedBack Thread [merged] (horror stories & others)
- May 2017
- 2,099
July 18th, 2020 08:26 PM #33
July 18th, 2020 09:03 PM #34
Para mapanatag loob mo palitan mo na lang mura lang mga parts na yan.
- May 2017
- 2,099
- 52,724
July 18th, 2020 10:26 PM #36in the first place,
why did you decide to have your vehicle checked?
were you feeling something abnormal now that wasn't there before?
i don't know about the others, but
my usual symptom of worn out suspension parts, is THE SOUND when i drive over un-even road surface. "lumalagutok." every car owner knows it. it's the sound of $$$.
i'm not going to bad-mouth rapide, but i would recommend you have your car checked elsewhere. the goodyear servitek is ok with me.
i have tried them, whereupon they said "ok pa naman ang inyo".
if you wish, you can have your alignment checked (again!). it is SOP kasi, that they first check the suspension for wear, before they align.
you can emphasize to them to "please check my suspension also", even as they really do it as a matter of procedure. aligning before fixing the worn suspension, is akin to throwing away money.
abutan nyo na lang nang kaunting tip.
suspension systems are usually long-lasting.
my 2005 innova with 130K km is still on its original suspension...
good luck.Last edited by dr. d; July 18th, 2020 at 10:37 PM.
- May 2017
- 2,099
July 18th, 2020 10:43 PM #37
July 19th, 2020 12:05 AM #38
Since pinacheck mo na rin lower arm pacheck mo na rin ball joint. Pag bushings bumigay maingay lang. Pag balljoint bumigay aray.
21k pesos for suspension arms sounds like brandnew sets. Some suspension shops can refresh your stock arms by just replacing the worn out parts.
Sent from my SM-A605G using TapatalkLast edited by JohnM; July 19th, 2020 at 12:08 AM.
- May 2017
- 2,099
July 19th, 2020 10:33 AM #39
I think okay naman ang balljoints and bushings kasi sa another tire service center ko dinala at chineck nila ang wheel alignment, kasi previously noong nagpawheel alignment ako ng another vehicle namin 2 years ago sinabi nilang kailangan munang ayusin ang balljoints and bushings para malagyan ng wheel alignment, pero for this Kia Sportage Vehicle, hindi naman daw naalis ang wheel alignment nya based from their findings...
July 19th, 2020 12:22 PM #40
Replace it nonetheless. Since pinagawa ko na, mura lang mga parts na yan.
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
