Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
    Apr 2014
    #31
    Quote Originally Posted by gomezgomez View Post
    Yan yung tunog, for reference nalang din. Tumutunog lang sya pag dine-depress yung brakes.
    Nangyayari rin sa cold start?
    The sound is kind of reminiscent of rear drum brakes not disengaging.
    If you have disc / drum, i know engaging the brake pedal wont engage the rear but it looks like you have an over aggressive drum brake hence it always engaged.
    Sep 2018
    #32
    Noise when using brakes isn't necessarily a reason to panic and stop on the roadside immediately. Some noise is usually normal that is probably affected by the weather or your driving habits. However, when you feel that the sound is unusual and very noticeable, it may mean something is wrong. These unusual sounds coming near or within your wheels can mean that your brakes need attention. A possible reason would be worn-out drums, rotors, calipers or brake pads that might need to be replaced. Since the car's brake is part of the car's safety system, it's best to repair it to avoid any unfortunate situation. What you can do is to bring your car to your trusted car shop to have it inspected for possible repair. Hope this helps!
    Jul 2014
    #33
    bro ano ang naging solution mo dito? brake pad nga ba? ganyan din kasi experience ko sa 1st gen ko na brio.
    Nov 2019
    #34
    Up ko lang sana thread na to.
    I am wondering if na resolve ni OP yung issue nya.
    Also experienced the same on a brand new car.
    #35
    Quote Originally Posted by carxynogen View Post
    car is parked outside?
    Nov 2019
    #36
    No, it is parked in a roofed garage.
    The sound will occur if I depressed the brake while on D gear mode.
    Dinig din siya if I move the steering wheel left or right turn without releasing the brake while on D gear mode.
    Aug 2019
    #37
    actually nangyayari din sa akin ito.
    Weird noise when pushing and letting off the brake pedal when at stops - YouTube
    especially during inclines. pag bibitawan ko na ung brakes.
    manual vios
    kla ko normal lang. hindi pala
    #38
    .. have the brake pads checked if there is uneven wear.. inspect caliper pins for any mechanical wead.. brake fluid bleeding..
    Nov 2019
    #39
    Will report to Casa on my 1st PMS.
    May 2019
    #40
    Try to bed your brakes, then report back.
Is it normal to hear a groaning sound when depressing brakes?
